The king's scepter Indigo
Posted: Tue May 31, 2016 9:47 pm
Hi
The king's scepter Indigo!
it's a matter of compressing those into a zip. the igs file most surely won't have any mesh in itself. When exporting a scene save as "pigs", this way it will export textures, meshes, whatever it needs.contegufo wrote:I have an error message
"The extension c4d is not allowed"
I put the file .igs
There's no reason that precedence has any impact in contrast. Precedence is used when different mediums are used (liquid/solid), not anything else.contegufo wrote:Hi
VoilĂ the file zip.
Increasing from 1 to 10 the value of "precedence" is obtained a greater contrast!
Indeed, when you set "precedence = 1" you're making it like air, and got those two as if they were the same medium.contegufo wrote:Hi
The two glass elements have "precedence" = 10, while in the first immgine = 1. As you can see there is no difference. Perhaps the environment is considered medium equal to the air?
Other explanations?
