Page 1 of 1
Ferrrari 458 Italia
Posted: Wed Sep 23, 2015 4:47 am
by contegufo
Hi
Some modest examples of rendering.
The model is challenging and the hardware is not up to the task then also scenes hide the inability of the writer.
The body is not as I would like and it is taken from the online database.
I have big problems with front and rear lights that I believe are among the most difficult things.
Even the glasses I wish I was more reflective.
If you load a standalone environment map in the application software is closed. I think it's a problem because the operating system before the upgrade did not happen.
All tips are welcome.
Re: Ferrrari 458 Italia
Posted: Wed Sep 23, 2015 6:27 am
by Oscar J
The glass and carpaint don't need to be more reflective, the just need something to reflect. Use an environment map, and try loading it into the Cinema 4D exporter.
I also get crashes when loading stuff from my local disk in Max OS X, it crashes under QT Core or something like that. Definitely something for the devs to look into, although I think they're already aware of the issue.
What problems do you have with your front and rear lights?
Posted: Thu Sep 24, 2015 4:11 am
by contegufo
Hi
I believe that the shader carpaint is not suitable for a red Ferrari (RGB 204,0,0) so I changed.
The problem of the rear lights is that they are two objects one inside the other. The inner one is chrome wrapped by red plastic.
Application stanalone I managed but there are big problems in Cinema also because of the preview that is very slow.
Posted: Thu Sep 24, 2015 4:39 am
by Oscar J
Pretty nice rear lights!
Posted: Thu Sep 24, 2015 6:50 am
by contegufo
Hi
The miracles of Indigo.
This is the partial result after only 4min. (1280x720 px)!
I think it takes an area ligth on the front.
Work in progress......
Posted: Wed Oct 07, 2015 11:31 am
by contegufo
Hi
Final rendering.
Posted: Thu Oct 08, 2015 5:57 am
by Oscar J
Your tires look just gorgeous in some of those pics. But a more interesting environment would certainly help to make the images more interesting.
Posted: Thu Oct 08, 2015 6:21 am
by contegufo
Hi
Thank you, unfortunately I have trouble finding adequate maps for a composition!
Posted: Fri Oct 09, 2015 2:55 am
by contegufo
Hi
Test floor.
Posted: Fri Oct 09, 2015 3:33 am
by Oscar J
Posted: Fri Oct 09, 2015 10:33 am
by contegufo
Hi
Thanks for the suggestions!
Posted: Tue Oct 13, 2015 12:21 am
by Juju
I'm sure I recognize a few of those...
