A natural situation
Onizuka
Re: A natural situation
Post by Onizuka » Sat Jun 18, 2016 11:19 am
Ok, I made a test the other day, with this parameters, but I'm not sure about the results, if you look at the sky colors ( or the color should be right if longer render time maybe I don't know, I had no more time to test this )
yonosoy
Post by yonosoy » Mon Jun 20, 2016 5:27 am
Hi Onizuka. Sorry for your scene.
The v4.0.38 still loose power with time, decreasing the samples/pixel of the scene, but not so much.
Jay-ko
Post by Jay-ko » Mon Jun 20, 2016 7:13 am
nice instagram effect :lol:
errare humanum est
yonosoy
Post by yonosoy » Mon Jun 20, 2016 9:53 am
Hi Jay-ko.
I can´t understand the joke, sorry.
But if there is something wrong with the picture just tell me to do it better in the future...
I´m not very good with the color...
yonosoy
Post by yonosoy » Mon Jul 25, 2016 6:25 pm
Another bidirectonal path tracing test over earth simulation with atmosphere. Sample quality is not very good but run on esteroides (8M samples/s in windows 8.1 and more than 10.5M samples/s in windows 10). Physical aperture difraction. There is a defect on the water bump.
The silver sphere has 1 km radius, so the islands are giant (I put this reference later). A little disaster but here goes.
yonosoy
Post by yonosoy » Mon Aug 01, 2016 8:08 am
Just realized that bidirectional mode works without the need of any trick for earth simulation (not for a patch !!).
Indigo v4.0.41 starts to sample but freezes at minute two.
Bidirectional metropolis because I want to capture the reflection of the physical aperture difraction. I must to compare it with a simple metro with post-pro aperture...
Still this defect on the bump, I don´t know why.
With circular aperture the speed is normal (867 k samples/s) and the samples are of a better quality...
Post by OnoSendai » Mon Aug 01, 2016 8:18 am
Cool.
Is the water a bump texture, or a shader?
yonosoy
Post by yonosoy » Mon Aug 01, 2016 8:32 am
A shader. Really strange...
The oceans mesh is highly poligonizated and has two subdivision with smoth on.
Nicole Kidman
Post by Nicole Kidman » Mon Nov 28, 2016 10:39 pm
Looks nice!
Thanks for the tip!
tell me please where you can download Indigo scenes examples? Exterior an Interior
yonosoy
Post by yonosoy » Thu Jan 21, 2021 10:21 am
So many thanks, Thread closed I miss this...
yonosoy
Post by yonosoy » Thu Jan 21, 2021 10:22 am
P.D. you can smell the road and pick up some examples of all.
Alamy
Post by Alamy » Mon Aug 01, 2022 11:42 am
Hi Yonosy!
Can you tell me how I can achieve this in Sketchup, Please
Alamy
Post by Alamy » Mon Aug 01, 2022 11:45 am
yonosoy wrote:
Tue Oct 20, 2015 10:26 pm
Working around with IES I realized that is not possible to simply apply the IES profile to the polygons of a bulb.
IES expetcs a simple polygonal plane. Almost here the light pattern of the IES is lighting from every polygon of the bulb with odd results.
Then I substitute some bulbs per polygons plane and the mie_cumulus phase per uniform and seems very correct.
Next to come some mist in a forest :) .
Also If you can help me to achieve this effect in Sketchup I will be grateful to you
yonosoy
Post by yonosoy » Mon Apr 03, 2023 6:49 am
Preview: Re: A natural situation
Tanks alamy for remove this closed thread.
Now is the moment for a reply...
The circumstance is this...
3.8, 20 minutes. Heavy weather.
donde está el pigs? seguro que lo tienes, el mio esta roto y perdido, demasiadas vueltas...
Pigs size 112 Kb.
Pigs size 112 Kb.
Estaba bien, pero el mapa de obstaculo fue un obstaculo ¿? siempre la difracción de apertura física se estropea cuando es una joya. Me quieres hacer creer que Nick es tonto también y se olvida de la diferencia?
Me hubiera interesado la esférica, porque es un HDR interesante. Pero tampoco funcionó su recuperación...
desde hel cielo
yonosoy
Post by yonosoy » Mon Apr 03, 2023 6:50 am
¿Porque le quitaís a mis chiquillos lo que Ël les trajo? Y quién eres tú, alicia?
Users browsing this forum: No registered users and 85 guests
