Page 1 of 2
Posted: Sat Jan 20, 2007 5:51 pm
by CTZn
I can make some 3d clumps of grass if you want Radiance, just tell me how they should look and thats almost done (Maya has presets to generate grass and trees and more, everything is customizable tho) ;)
:shock: I'm just flabbergasted by the specs of your scene !
Posted: Sat Jan 20, 2007 6:09 pm
by spy
impressive
grass seem a little dark.
maybe mix a little yellow and white.
AWESOME?
Posted: Sat Jan 20, 2007 6:27 pm
by oodmb
very tropical. sort of makes me sad. I love the way the scene transitions from the sky into the trees, its more than that its realistic! oh, and i actualy think it might ruin this effect if you let it render for longer, the grain adds to the tropical feel of this picture
Posted: Sat Jan 20, 2007 7:49 pm
by CTZn
Acknowledged, obj is my default format for export. I'm going to give it a try. Floor won't be included I think.
Posted: Sat Jan 20, 2007 8:31 pm
by CTZn
You've got a new message Radiance ;)
[EDIT] but I got to say the result may be unusable cause it's so heavy... lemme know how that has to be so I can do some better stuff (less density per surface ?). Btw the card method can be an excellent method, as sawn in the tut posted by Manitwo right next that post.
Posted: Sat Jan 20, 2007 8:49 pm
by Big Fan
edited to remove all
Posted: Sat Jan 20, 2007 11:59 pm
by manitwo
looking great radiance! :wink:
Btw: fantastic gras-tut: http://gallery.realistic-design.com/tut ... torial.pdf
Posted: Sun Jan 21, 2007 3:15 am
by domparis
Cool, great use of instancing, particulary on the litlle rocky ground !!
Dom
Posted: Sun Jan 21, 2007 5:59 am
by Kachu
Another fantastic render by radiance.
Posted: Sun Jan 21, 2007 8:45 am
by jansan
Wonderful work, to you this being excellent, simply, Is admirable, your work. I hope that you can, like sometimes previous to show to us since you did it. It said to Confucius a graphical bond by thousand words. and I add, and a Blend, is worth by a Million words. thanks
I hope impatient to see render, final
They remember to me, the works of Carma, my friend, the best in info architecture in my country
It uses, Max + Vray, and I am treating, comes to Indigo
http://i12.photobucket.com/albums/a237/ ... /v41c5.jpg
http://i12.photobucket.com/albums/a237/ ... amara3.jpg
http://i12.photobucket.com/albums/a237/ ... amara2.jpg
Re: samoa resort - v0.7test1 instancing rocks !!!
Posted: Sun Jan 21, 2007 11:02 am
by Bandar
radiance wrote:alpha textures using the blend and null material really rock.
Did I miss something?
I have to do some commercial (well not for money) archivis project. I'd like to render the building with indigo, but dont know, which technique I should use for the compositing. Any tips?
Posted: Sun Jan 21, 2007 8:34 pm
by OnoSendai
That is an insane amount of geometry :)
Posted: Sun Jan 21, 2007 8:50 pm
by CTZn
It is ! Glad I helped.
Blooming can be faked I think. Using a tonemapped exr you can keep the highlights only, export LowDR, gaussian blur them and comp over the original tonnemapped image.
Looking forward for a more advanced render ;)
Posted: Mon Jan 22, 2007 2:27 am
by jansan
Un trabajo Barbaro, Hiciste los pequeños arreglos que le hacia falta, y esta mortaaal, Espero verlo luego de ser cocinados por completo.
Excusa mi entusiasmo (ya lo pondre con traducion de google)
Posted: Mon Jan 22, 2007 2:28 am
by jansan
A Barbarian work, You made the small adjustments that him towards lack, and this mortaaal, I hope to see it after being cooked completely)
