Indigo beta 2.0.2
Indigo beta 2.0.2
This update fixes some localisation issues with european-style floats.
Windows 32 bit:
http://www.indigorenderer.com/dist/beta ... v2.0.2.zip
Windows 64 bit:
Os X:
http://www.indigorenderer.com/dist/beta ... seimage.gz
Licencing:
As before - a special offer for the beta group users - the first 100 people that choose to buy a Indigo Full Licence will get a lifetime of free upgrades. So that means you will get Indigo 3.0, 4.0 and so on - for no extra cost. If you are interested in buying this licence, you can access our store at:
http://store.glaretechnologies.com/
Windows 32 bit:
Windows 64 bit:
Os X:
Licencing:
Re: Indigo beta 2.0.2
when render is paused, time and samples still run. bug?benn wrote:This update fixes some localisation issues with european-style floats.
Windows 32 bit:
Windows 64 bit:
Os X:
Licencing:
Check normals, dude!
Yeah, I guess the timer should pause as well
Will fix.
Will fix.
I used last Cindigo and error with no description pops up in Indigo window, close Indigo, open from folder, load the scene, hit render and ... No problem!!!
That happens in both windows 32 and 64 versions.
Same thing with blendigo.
- pixie
This has to do with the way the .cmd is written (check cindigo plugin there will be a cmd file), it shouldn't have the cd before, it ought to be started with complete path name (c:/indigo/indigo.exe) and it shouldn't have spaces in the pathRafaello wrote:I used last Cindigo and error with no description pops up in Indigo window, close Indigo, open from folder, load the scene, hit render and ... No problem!!!
the cindigo .cmd file works with indigo_console.exe.Rafaello wrote:I used last Cindigo and error with no description pops up in Indigo window, close Indigo, open from folder, load the scene, hit render and ... No problem!!!
so if you dont really need the ui, you could use it.
Yes fused, I noticed that but I didn't know if that was a Cindigo problem or an Indigo one.
The behaviour in blender is the same and that confuse me, Is this an Indigo bug? or have to change something in the exporters?
I have noticed that 2.02 version is slower than 1.1.18
2.0.2 should be as fast or faster on most scenes. Nick did some changes to make lots of the vector maths use SSE, but we're pretty sure everything benchmarks faster than it did.
are you sure it wasa good idea to change to Qt libs for GUI? it seems to become a bit slower as wxWidgets.
It does seem a bit slower yeah - the wx one was probably better - but it's too late now.
Fixed for next release.SmartDen wrote: when render is paused, time and samples still run. bug?
Re:
Are you referring to the rendering speed (e.g. samples per second), or the responsiveness of the GUI?Rafaello wrote:Based on my tests I think that 2.02 is a lot slower and development based on 1.1.18 would be better for everybody
Hey Ono, I just tested 2.0.2 vs 1.1.18, and it seems that the new build is about 13% slower for me
My example scene took 2.21min to reach 100sp/s on 1.1.18, and 2.42min on the new 2.0.2 build
I also had to set refresh rate for the GUI to 20 sec to let both versions behave the same, because for the new version, the exported refresh timings get ignored, its hardcoded to 20sec!
I also realized a shift in the display of rendered EnvMaps (via material on backround!) by some degree...
Maybe the quality of your samples is better, but there are less :/
Well Ono, the gui responsiveness is slow when close a loaded scene with about 7 million vertices (more than 5 minutes and the dialog still there, had to shut down the process) same happens when exit Indigo with the same scene loaded.
I tested the scene for 7 hours and the final image was more undefined in the 2.02 version.
Sorry I did not look at the samples per second but I will try again an will tell you.
