Selective tone mapping?
What if you only wanted to tone map select parts of a render?
- Borgleader
- Borgleader
"Is it an hdri anyway", is asking Borgleader ?
You will not succed with a real paint and brush, try photoshop or gimp instead... ahem you know these softs allow you to select the portion of the image you want to work on. Okay neo, ask yourself your question and I'm sure you'll find a nice way, like using small weak emitters or putting hole in the plane to show an emitter behing, or draw white pixels or whatever... There are so many ways, and it's so easy to find one that you should take one moment of reflection before asking, really you are not nasty but harrassing
So, the question you really want to ask yourself is: "How can I make the stars showing more, or be brighter?". When you came to several options evaluate wich one you would like to apply, try it and then try the others if the first failed.
Yep, but rendering things changes the look of that image as a background. Im stil waiting for skindigo to support rendering background images. That would be amazing.Borgleader wrote:Isnt your background just one image? Like what that other guy did with his star wars scene?neo0. wrote:Well, for example.. Take my space scene.. I want to brighten up the stars but I don't want the clouds to glow like they're radioactive or something..
