1. contains a few little mods to make it compile under Dev-C++ 4.9.9.2.
* there were two (float) typecasts I think, and another (std::string) typecast.
* needed to change _asm syntax for dev-c++.
2. increased precision of PI and LN_2
3. completely changed the widgets layout.
4. removed auto-updating on slider change.
5. Added an "update image" button to apply current settings.
known problems:
1. when compiled with dev-c++ violet crashes on exit. Probably a problem with my setup or wx version or something. I'm assuming that this won't happen if this diff is merged into your own source.
my first patch
my first patch
- violet-dougalpatch1.diff.igs
- this is a .diff file. (ascii text)
- (12.94 KiB) Downloaded 200 times
- violet-dougalpatch1.jpg (55.76 KiB) Viewed 2319 times
added autoupdate checkbox
- violet-dougalpatch1a.diff.igs
- (13.83 KiB) Downloaded 178 times
I've put up a build in this thread:
http://www2.indigorenderer.com/joomla/f ... 8262#18262
SmartDen: try it out
