Im pretty confused?
Im pretty confused?
I read alot of forums but i still am not sure how to open igm or pgim files. Will someone make a tuturial with pictures? for blender
Re: Im pretty confused?
Double thread
Pgim files are essentially .zip files with the igm file and textures, while igm files are just the... igm files.
You use them by (or at least I do) extracting them to somewhere on your computer, then in the Blendigo exporter, you set the material type to external, and set the path to the igm file.
samlavoie.xyz
This needs to be explained better - but yes...
You set the material type to external, and set the path to the igm file.
