Introducing parametric ISL shaders
Ever wondered what ISL was ? Got the idea but can't get the how ?
Here: Glare Tech heads have made possible to shaders writers to build a simple UI for every Indigo user.
As a result you can now interact with the ISL shader in predefined ways, using common controls.
You will find the milled_aluminium in the database ready for your practical session. edit: Clik the rightmost control of the bump parameter to show the shader UI.
Have fun !
NB: as of Indigo 3.2.5, editing the material will reset its nk reflectivity to full throttle.
Have fun !
Re: Introducing parametric ISL shaders
THANK YOU! You read my mind! I took a stab at ISL and gave up quickly. No coding skills here haha. Thank you oh so much!
Wow! Thanks, so cool!
Thank you for your enthusiasm, thanks Glare for the tool !
I was to update the shader with an hammering effect but the two together don't cope with bump mapping, that's going to be a different material.
Very cool! Awesome work!
Next step would be to expose these shaders in host applications? I hope Blender gets custom nodes soon...
Thanks Tom !
Yes importing these parameters in the host application is an option wich makes sense with integrated rendering solutions. Perhaps Cindigo does such a thing already ?
Absolutely freaking (to not use another f-word) awesome !
anistropy possible ?
I did not quite ask for it. But, YES, that would be awesome!
Anisotropy is a bump effect indeed, but that's nothing new in the other hand ! See this material from Schosch:
http://www.indigorenderer.com/materials/materials/73
Didn't you know dcm ? Here's where it started all A user reported that this material was broken and it still is, I then did a mere copy in a hurry then considered a procedural approach.
The notice is recent therefore, I should have told you by another mean, apologies. Would you happen to have the source file still ?
We can look into having per cell pseudo-random rotation for the anisotropy direction added to a global rotation, plus the usual UV scaling tools. In fact I've mostly been exploring Indigo's voronoi function in these last materials. Now to 2x2 matrices I guess.
Let me know your preferences, not that I can everything but I like the challenge.
I have thought about your question again, I figured that you were perhaps under the impression that anisotropy was not possible in Indigo because of the ray nudge feature.dcm wrote:anistropy possible ?
Well, this limit would be a problem with displacement but bump mapping is somewhat special in this regard. Here's how I understood the issue (for opaque materials):
- - Bump mapping is considered only when a ray has hit a geometric surface
- If that surface is bumped the shading slope is then computed
- Based on that slope, if the outgoing ray direction is negative to the geometric normal the ray would die (black shading spot).
- Otherwise, it would be reflected, but since that would forcibly be away from the geometric surface (or it dies) there would be no further interaction with the bumped surface at the features scale. The ray origin nudge distance does then not apply.
Hoping that I am making sense as I had troubles finding the right ways of saying
Great work CTZn,
thanks for pushing and making use of this feature.
+1
This is awesome stuff!
I've tried the "anisotropy"-texture above or from the matdb before but the problem in case of my model is that I still have to UV unwrap it. It's a very triangulated mesh from a CAD application and unfortunately getting a clean undistorted UV map seems to be very difficult at best.
I'd love to have a 3D texture, comparable for example to Blender internal procedural texture. That would eliminate the need having to UV map everything.
No free lunch so far
Users browsing this forum: No registered users and 61 guests
