Error when try to dowload a material using "search method"
Hi there,
From the material window in Indigio I'm searching for a new materials and then when I'm trying to download one I got this error window: "Windows cant find wget.exe", anyone knows what is the problem?
Of course I'm modelling in Sketchup.
Re: Error when try to dowload a material using "search metho
I have the same problem. I have attached the error message. After I click OK on that it says that the material was successfully loaded, but it is not.
Can someone please help?
- Error message when attempting to load material into Indigo Renderer.
- wget.gif (5.42 KiB) Viewed 14435 times
Independently from your support request, you can tell Windows where to find specific dll's and executables by editing the PATH environment variable. Roughly (I'm using a french OS so items translation may use guesswork from you), here's the way:
Locate the wget application using Windows search. If this step fails you can forget about the method below :/
The other well known alternative is to drop files into the system(32) folder but I do not recommend this for you, might as well screw something on the wget side.
- Right-click on My Computer > Properties
Left pane, click Advanced System Settings
Down the popping window click Environment Variables
Seek for a variable called PATH (case sensitive) in either the user or system pool
Where you find it, edit the value; do not delete it's content. Make sure it is terminated by a semi-colon then append the path to the directory containing the wget application. Apply and close system windows, restart SU (or the system, to make sure).
I can not find anything named PATH, only PATHEXT:
.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
I do have path but it's lower case:
C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\QuickTime\QTSystem\
Please help.
Please help.
Given the accompanying data, path will do for you.
Again there is no guarantee I'm sorry to say, that's just the first step I would take with this (generic, Windows) error message, and having the required exe right on disk.
edit: I've just read your post according to wich you did not find wget.exe, that would be a showstopper regaring the metod hereby.
Showstopper; Are you also saying that wget.exe may actually not be included in 3.0.14 and that my 'theory' may be correct?
That's what I understood from your recent post in the SketchUp forum, rather. I don't know why this error is happening.
edit: in my case the application is present in the folder whaat is mentioning.
Could you check that out ? I suggest that we stick with the thread in the SketchUp forum to avoid further cross-posting... http://www.indigorenderer.com/forum/vie ... 17&t=11167Whaat wrote:If this file is not there, maybe some Windows security feature is blocking it....
I agree, and I have replied in the other topic now. Let's continue there.
Users browsing this forum: No registered users and 65 guests
