finding igs syntax and semantic tutorial
Tutorials/guides/tips on how to use Indigo and the Indigo exporters
7 posts • Page 1 of 1
moraton
Post by moraton » Tue Mar 29, 2011 7:46 pm
hello,
I don't find a tutorial or a technical reference who can help me about the igs file syntax and semantic. Do anybody know where I can fint it?
For example if I have this piece of code:
<background_settings>
  <background_material>
    <material>
      <name>background_material</name>
        <diffuse>
          <texture>
            <uv_set>albedo</uv_set>
            <path>C:\MyTexture.bmp</path>
            <exponent>1</exponent>
            <tex_coord_generation>
              <spherical>
                <rotation>
                  <axis_rotation>
                    <axis>0 0 0</axis>
                    <angle>1.6</angle>
                  </axis_rotation>
                </rotation>
           .... and so on ....
How can I set, for example, "<axis>" and "<angle>" parameters? What do they mean?
thanks for any kind of help!
bye!
Re: finding igs syntax and semantic tutorial
Post by CTZn » Wed Mar 30, 2011 4:50 am
Hi moraton, for what I can say axis is a 3d vector around wich the spherical projection is oriented/rotated, and angle is the amount of rotation expressed in radians.
1.6 radians ~= 90°+
moraton
Post by moraton » Wed Mar 30, 2011 9:15 pm
CTZn wrote:Hi moraton, for what I can say axis is a 3d vector around wich the spherical projection is oriented/rotated, and angle is the amount of rotation expressed in radians.
1.6 radians ~= 90°+
Thank you, but what about the tutorial of igs syntax and semantic? Is there nothing?
Post by CTZn » Thu Mar 31, 2011 10:13 am
Nothing official beside the technical documentation. Many code snippets can be found throughout the site, though. Check also the Indigo release threads where new functions were intoduced.
ISL is aimed at coders and operators with a former knowledge in shading bits.
galinette
Post by galinette » Thu Mar 31, 2011 8:56 pm
Maybe you are just looking for the technical documentation, it can be found here:
http://www.indigorenderer.com/support
It's not totally up to date, though.
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
moraton
Post by moraton » Fri Apr 01, 2011 12:29 am
Thank you so much, now I understand how it work.
Thanks again
Post by CTZn » Fri Apr 01, 2011 3:41 pm
I wasn't clear enough, sorry moraton: the technical reference PDF is also shipped with Indigo :)
Users browsing this forum: No registered users and 78 guests
