Page 1 of 1
Sorry if this sounds like a dumb question
Posted: Mon Aug 31, 2009 2:55 pm
by neo0.
As people here know, my knowledge of coding is basically zero.
Have there been any thoughts about switching from HTML to C++ or something? In my mind, there would be many benefits like :
- No more red x as placeholders for material previews (you can have much more control over the UIs visualdesign.) No more hard edged square buttons!
[*']Much more functional flexability. Customizable hotkeys, docking/undocking, widgets, etc. Maybe even combining interactive and visual elements (like adding pause/play buttons over the material preview.)
- Animated UI!
Re: Sorry if this sounds like a dumb question
Posted: Mon Aug 31, 2009 3:09 pm
by Borgleader
Well for one, by looking at the files (in the latest Skindigo.zip) the code for exporting mesh & such seems to be written in Ruby? (not HTML, that's only the interface part of it, as far as I could tell). There's also the issue of linking the exporter to Sketchup. I'm unfamiliar with it but if it's like blender it won't be able to "communicate" with a script written in any language. (after a bit of research it seems it only allows Ruby
http://code.google.com/apis/sketchup/)
And even if it did, it would probably mean Whaat would have to learn to code in C++ which is no small task. ("Fun fact" I've bought the book for my "Procedural Programming" class in Uni which is an intro to programmin in C++ and its 650 pages long).
As for the visual stuff, well I guess it's just a matter of finding the right application to create the interface.
Posted: Mon Aug 31, 2009 3:12 pm
by neo0.
Well, I meant changing the UI. The actual exporter could be written in any language..
Posted: Mon Aug 31, 2009 3:14 pm
by Borgleader
neo0. wrote:Well, I meant changing the UI. The actual exporter could be written in any language..
Well I'm no coding experter (yet) but hmm it would be a matter of integrating the ruby code into something else than HTML. And I'm unsure which other possibility(ies) there are.
Posted: Mon Aug 31, 2009 3:27 pm
by Whaat
I assure you that the HTML interface is here to stay. All of those UI requests that you mention in the first post can be done with HTML and javascript. The UI will continue to improve over time as my knowledge of HTML and javascript increases.
Also, I am sure that benn will be helping to improve the UI as his knowledge in javascript is much greater than mine.
by Borgleader
Whaat wrote:I assure you that the HTML interface is here to stay. All of those UI requests that you mention in the first post can be done with HTML and javascript. The UI will continue to improve over time as my knowledge of HTML and javascript increases.
Well I guess everyone will be happy then!
Posted: Mon Aug 31, 2009 5:56 pm
by benn
Exactly what Dale said. Stop trolling neo0 ;D
