Page 1 of 1
Skindigo not Running on Vista 64
Posted: Tue Feb 03, 2009 3:38 pm
by fireworkspete
I am running Vista 64 bit edition.
I have installed Indigo and Skindigo correctly but it will not work with sketchup. I can open Indigo separately and run an igs file from there, however if I try to render from sketchup nothing happens besides it saying that it exported X number of triangles in x number of seconds.
I've given Indigo the correct number of privileges and removed all restrictions from it, however I am still unable to get it to work.
Help please.
Thanks for your time.
Help please?????
Posted: Mon Feb 09, 2009 8:34 am
by fireworkspete
I'm wondering if anyone has had a similar issue as it is continuing for me.
I hit the render with indigo button, it says its exporting all the triangles...then nothing, nadda, niet.
I also won't save a Igo (or whatever the file type is.) I've tried most of the versions of Skindigo and of Indigo, both the 32 and 64 bit.
Anybody? Please? I'm getting a bit desperate here.
Posted: Thu Feb 12, 2009 6:31 am
by Whaat
open the Ruby Console window when you try to render and let me know if there are any error messages.
Ruby
Posted: Thu Feb 12, 2009 7:09 am
by fireworkspete
Here is the message I get.
"------SkIndigo Export Run------"
"Faces 19"
"Instances 0"
"Material Meshes 7"
"Component Meshes 0"
"Spheres 0"
" exported in 0s. "
Error: #<Errno::EACCES: Permission denied - C:\Program Files (x86)\Google\Google SketchUp 7\Plugins\indigo_x64_v1.0.9_2/autorender.bat>
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SkIndigo_1_0_9.rb:684:in `initialize'
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SkIndigo_1_0_9.rb:684:in `new'
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SkIndigo_1_0_9.rb:684:in `create_batch_file'
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SkIndigo_1_0_9.rb:541:in `export'
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SkIndigo_1_0_9.rb:5989
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SkIndigo_1_0_9.rb:5989:in `call'
Thank you.
Peter
Posted: Thu Feb 12, 2009 8:38 am
by cpfresh
isnt this due to the security settings in vista? you should move your indigo installation directory out of the program files directory.
Running
Posted: Thu Feb 12, 2009 8:46 am
by fireworkspete
Ayup, that was it, moved it to my documents and it runs fine now. Thanks a bunch. I'll remember it for the future.
Peter
Posted: Mon Feb 16, 2009 3:18 pm
by neo0.
This a great example of why I regret getting Vista. It literally stops you from using your computer.
Posted: Mon Feb 16, 2009 6:15 pm
by CTZn
[OT]
Ah, I didn't know that about Vista... I simply never install in that folder, it's so much of a mess from scratch... I'm using a custom 'c:\progs\' as root of any installation (just removing "ram File" from default install path). Lol. XP here, limited enough with 2GB already.
[/OT]
