Page 1 of 1
queue a rendering?
Posted: Thu Sep 25, 2008 10:16 pm
by reffo
did anyone know a way to queue a rendering with indgo..
I would like to rendere the 4 scenes , one afther the finish of the other..
(setting the time. etc,.)
Posted: Fri Sep 26, 2008 12:34 am
by SmartDen
write a little batch skript
Skript?
Posted: Fri Sep 26, 2008 5:35 am
by reffo
ok it's good advice. I like work into things,.
will be like.. C:
cd C:\Program Files\indigo_v1.1.5
start /wait /low /max indigo.exe "C:\Program Files\indigo_v1.1.5\piantachiusa/piantachiusa-0.igs" -o "C:\Program Files\indigo_v1.1.5/renders/piantachiusa-0.png"
where I can Set durating of the render and other commands .. Actually can I mak a bat of the 4 scenes and then erase the images beetween.??
thnks
Posted: Fri Sep 26, 2008 6:58 am
by cpfresh
set up your scenes and use an animation export. like you said be sure to set up your render duration. there was a pretty lengthy discussion on this somewhere in the sketchy forum. one issue that has arisen lately with the newer version of indigo is there is no exit or closure of the indigo window on completion which left the animations halted waiting for the return from the window closure ... (make any sense?) this was also discussed here and there. i havent tried it again lately to see if the issue was resolved. gl.
DIY
Posted: Sat Sep 27, 2008 5:51 am
by reffo
Ok.. good the advice of the batch..
but. here a quick solution I Do It by Myself
. 1: reating the scenes
2. setting delay scene to 1
4. setting the halt time of the render to wath you think is enought
3. doing the animation (output options)
4) settin g the frame rate to 1 (that was obviusly)
5 starting th bat,
bye!
