Page 1 of 1
MAterial Database Question
Posted: Sat Jun 14, 2008 5:20 am
by SlimTrigger
Where do I need to put the files for when I download a texture from the mat database?
Posted: Sun Jun 15, 2008 12:34 am
by fused
you should import them in skindigo.
look out for sth thats called "import igm".
Posted: Fri Jun 20, 2008 12:01 pm
by neo0.
Which version supports IGMs?
Posted: Fri Jun 20, 2008 1:34 pm
by Whaat
version 1.1.5 has the best IGM support. it will continue to improve over time. You'll have to have some patience as the kinks get worked out. The biggest problem is that many of the materials that are currently in the database are not valid IGM files so they might not load properly in SkIndigo.
Be sure to download Indigo 1.1.5 if you are using SkIndigo 1.1.5
