Setup troubleshooting, Please assist.
Posted: Thu May 01, 2008 12:03 am
Hello,
My sketchup location is "C:\Program Files\Google\Google SketchUp 6"
and my OS is windows vista business.
I'll run you through what I did.
-I downloaded the files "SkIndigo_1_0_8.zip" and "indigo_v1.0.9_3.zip" from the downloads section of this website.
-I extracted the files from the "SkIndigo_1_0_8.zip" ("SkIndigo_1_0_8.rb" and the folder "SkIndigo") and placed them both directly into the "Google SketchUp 6\Plugins"
-I extracted the folder from "indigo_v1.0.9_3.zip" ("indigo_v1.0.9_3") and placed it inside "C:\Program Files\Google\"
-I found a sketchup file on the web somewhere called Skindigo_09 Getting Started which I opened(I was at this point prompted to locate the Indigo.exe file which I did) and read through it. I realise this is an out of date guide but still I got some information out of it.
The problem arises when I am Running sketchup and click "Plugins">"SkIndigo">"Render Image" when at the bottom left corner of the screen it goes through a series of things "writing planes", "writing mesh", "exporting textures" which all happens over the course of a few seconds and then it stops as if nothing happened... at this point I'm stumped.
I did a search on "my computer" for "*.igs" but nothing turned up.
what does this all mean? are indigo v1.0.9_3 and the skindigo v1.0.8 not compatible or am I just missing something entirely
Thanks for any help.
-S
UPDATE:
I exported .igs files with skindigo v1.0.8 via plugins>skindigo>export scene as...
opened it with indigo v1.0.9_3 and this is what happens:
I also tried it with some of the testscenes in \indigo_v1.0.9_3\testscenes
same prompt, but I do get some different text in the lower box that you can see in the above image... any idea's?
also I read in the Skindigo "previews set - readme.txt" that I should put a previews folder into the indigo folder... what previews folder is that?
-S
UPDATE:
