Page 1 of 1
Alpha map
Posted: Thu May 31, 2007 10:31 am
by ciccio
Hello to all, I to be new of the forum of indigo. I to ask one gentility like using alpha map (clip mapping) in indigo?
example the leaf :roll:
I use Sketchup
Posted: Thu May 31, 2007 7:12 pm
by Zom-B
Welcome to the Forum Bruce Lee!
Take a look at this tutorial,
consider next time to post your threads in Sub Forums they fit to :wink:
Here is the SketchUp sub forum...
Posted: Fri Jun 01, 2007 12:25 am
by ciccio
tank very much ZomB :wink:
Grazie!
Posted: Fri Jun 01, 2007 12:37 am
by ciccio
to be tutorial for blender. to be the same thing SU - Blender?
Posted: Fri Jun 01, 2007 12:46 am
by manitwo
*moved*
Posted: Fri Jun 01, 2007 2:20 am
by Kram1032
*moved*?
Posted: Fri Jun 01, 2007 2:24 am
by ciccio
:shock:
Posted: Fri Jun 01, 2007 2:27 am
by Kram1032
:?: :shock: :?:
Sorry, I can't answer the question, as I don't use Sketchup myself, but
*moved* :?:
Has this been in an other forum, before?
Posted: Fri Jun 01, 2007 2:30 am
by Whaat
Welcome, ciccio!
To use Alpha Maps in SkIndigo 0.7.1, you need to create two materials in Sketchup.
- Material #1 ("Leaf") has the leaf texture applied to it.
- Material #2 has the alpha map applied to it.
- Set Material #2 type to 'Blend'
In the 'Blend' settings:
- Set Material A to "None" (will replace the black areas of the alpha map)
- Set Material B to "Leaf" (will replace the white areas of the alpha map)
Use the Sketchup Paint Bucket to paint your faces with Material #2 (the Blend Material)
Make sure you are not using version 0.6. It does not support alpha maps.
Attached is a Sketchup file showing an example of using an alpha map to create grass.
Posted: Fri Jun 01, 2007 4:15 am
by ciccio
tank very much Whaat
Grazie! :wink:
Posted: Fri Jun 01, 2007 4:20 am
by A_Minima
Not the thread subject but studying the Whaat's file : are you a French-speaking person Whaat ? (regarding to your maps name for the grass map into the SU material edit menu).
Posted: Fri Jun 01, 2007 4:38 am
by manitwo
Kram1032 wrote::?: :shock: :?:
*moved* :?:
my god, please think before posting! (if you investigate a few second in thinking and rereading you will be able to answer it yourself)
Posted: Fri Jun 01, 2007 4:39 am
by Whaat
A_Minima wrote:Not the thread subject but studying the Whaat's file : are you a French-speaking person Whaat ? (regarding to your maps name for the grass map into the SU material edit menu).
Sorry, I don't speak any French except for the few words I have picked up living in a bi-lingual country. I have some French connections, though. My brother married a girl from the west coast of France and my parents just got back from a vacation in France. I downloaded the textures and never changed the names so that's why they are French.
Posted: Sat Jun 09, 2007 11:21 pm
by ciccio
Ok Grazie!!! Thanks of the councils :wink:
