SkIndigo 4.4.10.1
14 posts • Page 1 of 1
SkIndigo 4.4.10.1
Post by OnoSendai » Thu Jul 16, 2020 12:09 am
RBZ:
http://downloads.indigorenderer.com/dis ... 4.10.1.rbz
Windows Installer:
Changelog:
4.4.10.1
Added new fabric material type.
Fixed section plane export resulting in a scene load error.
Enrico
Re: SkIndigo 4.4.10.1
Post by Enrico » Thu Jul 16, 2020 9:04 am
Hi Ono!
In my case the parameters "Roughness" and "Sheen Weight" of the fabric material set in Skindigo, are not loaded into Indigo, which maintains the default parameters.
Alamy
Post by Alamy » Mon Jul 20, 2020 2:04 am
Hi OnoSendai,
I purchased Indigo recently, is there any plans to develop the Sketchup plugin so it will be more compatible with Sketchup same like the cinema 4d plugin ... Thanks.
Post by OnoSendai » Tue Oct 06, 2020 12:39 pm
Hi Ono!
This is working as intended, what's happening here is that you have selected 'SketchUp' in the map drop-down box. This means that the roughness and sheen weight paramaters are using the SketchUp texture map to control their values.
Post by OnoSendai » Tue Oct 06, 2020 12:43 pm
Hi OnoSendai,
Do you mean an embedded plugin to SketchUp?
That is something we have though about and even experimented with.
Alamy
Post by Alamy » Sat Oct 24, 2020 8:17 pm
Hi OnoSendai,
Yes, that's what i mean exactly, so is there any good news about it soon?
Lal-O
Post by Lal-O » Mon Mar 22, 2021 8:31 am
How to set the "NULL" material in the material editor?
Post by OnoSendai » Mon Mar 22, 2021 12:34 pm
Hmm I'm not sure if there is an easy way to create a NULL material in SkIndigo currently.
Lal-O
Post by Lal-O » Mon Mar 22, 2021 1:10 pm
Ok, then i will set it in indigo 👍🏻.
Lal-O
Post by Lal-O » Tue Feb 22, 2022 1:03 pm
Hi. I have noticed that the "UV Mapping " option is not workin anymore (https://www.indigorenderer.com/document ... uv-mapping). I've tried lots of times and 95% of the times is not working. Would you please take a look ?
Thx :D
Lal-O
Post by Lal-O » Thu Feb 24, 2022 12:50 pm
Thx :D
Any News? :(
Alamy
Post by Alamy » Wed Mar 02, 2022 4:24 am
Thx :D
Any News? :(
Hope to hear any updates soon.
Lal-O
Post by Lal-O » Wed Mar 02, 2022 6:35 am
Thx :D
Any News? :(
Me too :?
Enrico
Post by Enrico » Thu Apr 18, 2024 2:53 am
Hi guys!
We have a serious problem...
Skindigo 4.4.10.1 doesn't work with the last version of Sketchup (2024). I tried to install and uninstall the program but the problem persist.
With the version 2023 the problem doesn't sussist.
I attach the string of the error!
<internal:C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in `require'
C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/skindigo/skindigo_core.rb:80:in `<top (required)>'
C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in `require'
C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in `load'
C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/skindigo.rb:19:in `register_extension'
C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/skindigo.rb:19:in `<module:SkIndigo>'
C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/skindigo.rb:4:in `<top (required)>
We need an update of the exporter!
Thak you guys
Users browsing this forum: No registered users and 108 guests
