Page 1 of 1
Roughness
Posted: Wed May 10, 2017 11:33 pm
by nmeau
Appears that Roughness doesn't export correctly through Skindigo - value does not change
Re: Roughness
Posted: Fri May 19, 2017 3:10 am
by OnoSendai
Which material type is it not working for? phong, coating etc..?
Re: Roughness
Posted: Sun Dec 16, 2018 10:20 am
by nmeau
Hi OnoSendai - I've linked to a very simple Sketchup 2018 file illustrating the problem.
https://www.dropbox.com/s/w82g37cfm0aux ... t.skp?dl=0
With the Phong material, I seem to be unable to apply any sort of map for the roughness setting. The material continues to be either fully glossy (in this case), or becomes entirely rough. No gradient, no matter how I change the settings.
Also from working with other files, it seems that the skindigo roughness settings are fickle and often don't export correctly.
I'd appreciate your take on this.
Cheers
