100 licences released https://gumroad.com/l/skatter
Don't know though if it is compatible with Indigo...
Skatter for Sketchup
Re: Skatter for Sketchup
regarding compatibility: http://www.indigorenderer.com/forum/vie ... 17&t=13524
- Antonis777
I suppose it's a no, although skatter's website claims to be supported by all render engines. For generating components that is...
I'm going to explain it the way I understand it
you will be able to render the Skatter generated objects with Indigo, however it will not be optimized as it is with certain other rendering engines
what happens with the optimization is that the objects are "skattered" but not directly transferred into SketchUp, the information gets passed onto the rendering engine about the object distribution etc.
if a rendering engine is used that hasn't been optmized then you can get Skatter to show the objects in SketchUp and the info will be passed along using the rendering engine exporter, but this would tax your hardware and SketchUp session, possibly causing something (SketchUp) to fail, and thus your rendering as well
- Antonis777
Ok it's all clear now. Any thoughts of the Indigo team to include this feature now that it's released? Let's hope and support so.
Users browsing this forum: Ahrefs [Bot] and 84 guests
