Page 1 of 1
SkIndigo 3.8.24 (beta)
Posted: Fri Dec 19, 2014 5:44 am
by OnoSendai
Changelog:
Improved external obj mesh support - automatically adds and converts materials from the obj and mtl files.
Fix/workaround for 'reference to deleted Entity' problem in some cases.
Minimum required Indigo version is 3.8.11.
RBZ: (Works on all platforms)
http://downloads.indigorenderer.com/dis ... 3.8.24.rbz
Windows Installer:
If anyone gets a 'reference to deleted Entity' error message, please stop, write down what steps you just took, and send me the .skp scene! (support@indigorenderer.com)
Re: SkIndigo 3.8.24 (beta)
Posted: Sun Dec 21, 2014 11:31 pm
by nosek1995
It's not working. I installed everything, following the instructions. I have SketchUp 2015. Everytime I open it a thing like that pops out:
Error Loading File C:/Users/Właściciel/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/skindigo/skindigo_core.rb
Error: #<LoadError: No such file or directory -- C:/Users/Właściciel/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/skindigo/SkIndigoUVS.rb>
C:/Users/Właściciel/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/skindigo/skindigo_core.rb:12:in `load'
C:/Users/Właściciel/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/skindigo/skindigo_core.rb:12:in `<top (required)>'
C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in `require'
C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in `load'
C:/Users/Właściciel/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/skindigo.rb:19:in `register_extension'
C:/Users/Właściciel/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/skindigo.rb:19:in `<module:SkIndigo>'
C:/Users/Właściciel/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/skindigo.rb:4:in `<top (required)>'
Help me! Please!
Posted: Tue Dec 23, 2014 3:18 am
by Pibuz
99 over 100% the problems are caused by the non-english characters on the username you use.
Posted: Tue Dec 23, 2014 3:22 am
by OnoSendai
Pibuz wrote:99 over 100% the problems are caused by the non-english characters on the username you use.
Unicode support should be working properly in SketchUp 2015 though.
Posted: Tue Dec 23, 2014 3:24 am
by Pibuz
..reading from the second line "C:/Users/Właściciel/" sketchup seem not to be finereading the path..
Posted: Tue Dec 23, 2014 4:19 am
by OnoSendai
Just tried with a Unicode user name, indeed there are problems with SketchUp 2015, sorry about that, will fix!
Posted: Wed Dec 24, 2014 2:12 am
by OnoSendai
This is actually quite tricky to fix due to many bugs in Ruby. (the language used for SketchUp plugins)
Still working on it..
Posted: Wed Dec 24, 2014 2:49 am
by nosek1995
Ok I'll dig into it and see what will happen when I change folder names :) Thanks for the help ;)
Posted: Sat Dec 27, 2014 9:24 pm
by snorky
just a test...
why does the scattered tree have wrong texture?
Posted: Wed Dec 31, 2014 7:32 am
by Aflac
I too am having the problem of scattered objects not having the correct materials. In my case the scattered objects are linked obj files and they are rendering with the 'default' material.
Posted: Fri Jan 09, 2015 5:41 am
by OnoSendai
nosek1995 wrote:It's not working. I installed everything, following the instructions. I have SketchUp 2015. Everytime I open it a thing like that pops out:
Help me! Please!
Please try the new build here and see if it helps: http://www.indigorenderer.com/forum/vie ... 17&t=13417
Cheers!
Posted: Wed Jan 14, 2015 4:47 am
by OnoSendai
snorky wrote:just a test...
Snorky: Please try this build: http://www.indigorenderer.com/forum/vie ... 17&t=13424
and tell me if it fixes this problem.
If it doesn't, please send me the .skp (and any external mesh files etc..)
Posted: Wed Jan 14, 2015 4:48 am
by OnoSendai
Aflac wrote:I too am having the problem of scattered objects not having the correct materials. In my case the scattered objects are linked obj files and they are rendering with the 'default' material.
please try http://www.indigorenderer.com/forum/vie ... 17&t=13424
