Automatic material mapping between SU and Indigo
Posted: Tue Feb 25, 2014 2:23 am
Hello *,
I have the following problem:
- I use a specialiced 3D modelling application, which has the possiblity to export the result as .SKP file
- this SKP File can be opened and modified via Sketchup without any problem
- But what I have to do is to define the indigo material parameters for each material
- Actually I have to define these material settings for each exportet model
Therefor my Questions:
- Is there any possiblity to automativally map the Sketchup and Indigo Material?
If yes:
- How does it work?
- What do I have to do to reach this goal?
At the moment I have to assign the right material settings via graphical user Interface. The exported Model contains always the same material names. The number of possilbe materials is round about 40. Therefor it would be really nice, to automate this material settings. I only want to define my Indigo material parameters once and everything else should work without additional interaction. With a possiblity of automatic mapping between the Sketchup and Indigo material the whole process of rendering could nearly fully automated.
I hope that anybody has a solution for this challenge.
Many thanks and best regards
Automation
If yes:
- How does it work?
Automation
