Page 1 of 1
SkIndigo 3.4.19
Posted: Wed May 29, 2013 4:22 am
by OnoSendai
This is a new build for Indigo 3.4.x, mostly to fix compatibility problems with SketchUp 2013.
Changelog:
Version 3.4.19:
Updated Windows installer to detect SketchUp 2013.
Fixed HTML issue with SketchUp 2013.
Fixed problem with material names with '&' in them.
Fixed problem with thin glass with special XML chars in the material name.
Download:
Windows:
OS X:
New build - version 3.4.19b
http://downloads.indigorenderer.com/dis ... .4.19b.rbz
Re: SkIndigo 3.4.19
Posted: Wed May 29, 2013 10:14 pm
by Pibuz
Cool! Thanks!
..I'll stick to sketchup 7 and 8 still for a while though.. Never been too excited about new releases of softwares
See windows, autoCAD,........EXCEPTED FOR INDIGO! I think I've never found more stable beta version in any other software. Which proves that the Indigo team is working reeeeally well for me. Thanks Glare.
Re: SkIndigo 3.4.19
Posted: Fri May 31, 2013 4:03 am
by OnoSendai
Added RBZ file for OS X users.
Re: SkIndigo 3.4.19
Posted: Tue Jun 04, 2013 5:58 am
by OnoSendai
Hi All,
There is a problem with SketchUp 2013 on OS X and SkIndigo, which results in this error if you change any render settings:
Scene parsing error: Failed to parse integer from ''. (In element 'renderer_settings', around line 12, column 9)
It seems to be due to a bug in SketchUp 2013. We're trying to either find a fix or a workaround as soon as possible.
Re: SkIndigo 3.4.19
Posted: Tue Jun 04, 2013 9:36 am
by OnoSendai
Updated first post with a new 3.4.19b .rbz for workaround of SketchUp 2013 on OS X issue.
Re: SkIndigo 3.4.19
Posted: Fri Jun 14, 2013 9:22 pm
by henrib
Hello,
there is an other bug, i think. On Mac 10.8.4 and SU2013, It's impossible to change Emitter attributes. If i change attributes, no export is possible.
"Scene parsing error: Failed to find child for element 'constant' - Child should be one of 'blackbody', 'peak', 'regular_tabulated', 'rgb', 'uniform'. (In element 'constant', around line 236, column 21)"
Same problem with the SKIndigo 3.6.14 from whaat.
Thanks,
Henri
EDIT : The fresh update of Sketchup 2013 fix the problem.
Re: SkIndigo 3.4.19
Posted: Sat Jun 15, 2013 6:08 am
by Whaat
henrib wrote:Hello,
Thanks,
Henri
Yes, they just released a maintenance update for SU2013 which should fix all the problems that Mac users might be experiencing.
Re: SkIndigo 3.4.19
Posted: Sat Jun 15, 2013 9:36 am
by OnoSendai
Whaat wrote:henrib wrote:Hello,
Thanks,
Henri
Great
Re: SkIndigo 3.4.19
Posted: Tue Jun 25, 2013 11:18 am
by Enrico
Hi One Sendai, I have finded problems into the "Skindigo Material Editor". The options "Search" and "Assign preset" don't allow to scroll material's previews as precedent versions of Skindigo. It's possible to verify the problem? Thanks!!
Re: SkIndigo 3.4.19
Posted: Fri Jul 05, 2013 12:58 pm
by renata.ferro
I just installed Indigo RT trial version to test it on my sketchup projects. However, when I click on 'render with indigo' inside sketchup, nothing happens. I have no clue what is going on.
Re: SkIndigo 3.4.19
Posted: Tue Jul 09, 2013 3:05 am
by Whaat
Enrico wrote:Hi One Sendai, I have finded problems into the "Skindigo Material Editor". The options "Search" and "Assign preset" don't allow to scroll material's previews as precedent versions of Skindigo. It's possible to verify the problem? Thanks!!
Hi Enrico,
What version are you using? OSX or Windows? Can you post a screenshot of the problem? Can you open the ruby Console window and check for error messages? Thanks.
Re: SkIndigo 3.4.19
Posted: Tue Jul 09, 2013 3:06 am
by Whaat
renata.ferro wrote:I just installed Indigo RT trial version to test it on my sketchup projects. However, when I click on 'render with indigo' inside sketchup, nothing happens. I have no clue what is going on.
Hi renata,
What version are you using? OSX or Windows? Can you open the ruby Console window and check for error messages? Thanks.
