Problem Working with Linux Indigo RT on Exported SU Scene
Posted: Sun Feb 24, 2013 1:36 pm
Hello All,
I'm new to this render, and a long-time user of SU.
Currently, I run a 64-bit Linux host running Windows 32-bit in a virtual machine.
I use SU natively within that Windows VM, and hope to do my rendering on my host box (the Linux 64-bit OS).
So my process is to build out my SU scene, use SkIndigo to export the scene to my Linux host, and... in theory... open and render that scene in Indigo RT.
HOWEVER... the problem appears to be that meshes in the resulting export are all relative to the originating box, and so the import into Indigo RT fails with the following:
Scene parsing error: Error loading model 'C:\Users\richbl\AppData\Local\Temp/ba2eb3c8-57e6-4554-8cbc-902bf47621ff.igmesh': Failed to open file 'C:/Users/richbl/AppData/Local/Temp/ba2eb3c8-57e6-4554-8cbc-902bf47621ff.igmesh' for reading. (In element 'mesh', around line 3, column 9)
Indigo version: Indigo RT v3.4.18, Linux 64-bit build.
No metadata.
Please contact support@indigorenderer.com if you have any questions.
Is it not possible to export scenes between machines, as I had hoped to?
Thanks much.
Rich
No metadata.
Thanks much.
Rich
