Indigo w/xsi mod tool
Does the exported work with mod tool also? If not, how hard would it be to adapt it?
Hi neo0,
sincerely i've never tried. it up to you to check and verify.
There aren't limitation by the exporter point of view...the only open point is to verify if Modtool is able to handle xsiaddons. In any case the exporter isn't designed to work as a renderer so Modtool should make it work.
In any other case, but due to development of IndigoTinted For XSI, there's no plan to continue XSIndigoExporter. I apologize for this.
Regards, Riccardo.
Regards, Riccardo.
