Announcements, information, requests and support regarding other exporters and general/new exporters
spludge
by spludge » Sat Aug 23, 2008 10:56 pm
Can not scenes with textures to work and always this error message:-
the texture "whatever.jpg" could not be bound to uvSet . . etc . . because that uv set was not exposed in an expose_uv_set_element.
I have frozen the texture support in its ppg AND on the MCP and specifically applied the projection in the image ppg.
I am using XSI 7 which seems to work fine apart from this problem.
rgigante
by rgigante » Mon Aug 25, 2008 9:32 pm
Hi Spludge,
XSindigoExporter has not been tested under XSI 7.0. Probably the error you're referring should be investigated together with 7.0. Could you please try to replicate the same behavior using 6.xx?
That would be great to better understand and go on in debugging.
Thanks, Riccardo.
spludge
by spludge » Tue Aug 26, 2008 7:46 am
Tried it with 6.5 and it worked fine.
I found that the plugin didn't work at all with 6.5 at first because I installed it via the plugin manager. I re-installed it by dragging and it worked.
7.0 seems to work OK apart from the image based texture thing.
rgigante
by rgigante » Tue Aug 26, 2008 8:13 pm
Thanks Spludge for the info. Asap i'll put hands on 7.0 i'll try to release a fix for textures.
Regards, Riccardo.
