Page 1 of 1
how to make materials for indigo in maya?
Posted: Mon Jul 14, 2008 6:58 pm
by roville_csb
Hi guys! im new here. how do you make materials for indigo in maya?
guys what the differences between pigm and igm materials?
Posted: Mon Jul 14, 2008 7:59 pm
by roville_csb
hi guys what is the difference between a pigm and a igm materials? how do make .igm materials for maya?
Posted: Mon Jul 14, 2008 9:53 pm
by dougal2
Firstly you can create materials for indigo in the hypershade using the indigoShader shader. If you don't see that available, go to the plugin settings window and see if it's there. If it is, load it and choose autoload too.
If you don't see the indigoShader.py in that list, you may have to browse for it manually. It should be in <my documents>\maya\<version>\scripts\MayaToIndigo\indigoShader.
If the plugin was not auto-loaded this also indicates an installation error, and I'd be interested to know if you encountered any errors in the install process and what they were.
Secondly, you can use .igm materials in Maya by selecting an object, and using the IGM button on the GUI. (I think it may be unlabelled still, but the status bar will tell you what the buttons do when you hover over them).
You will then be asked to find a .igm file and MtI will create the necessary shaders to use the material in your scene.
To generate .igm files at export time from your existing materials, you should enable the [] igm checkbox on the GUI.
The difference between pigm and igm is that pigm is really a .zip file that contains both the igm file and also any texture images it uses. MtI can't yet make pigm files directly, but indigo can on the command line.
Posted: Thu Nov 27, 2008 3:49 am
by Sinister
sorry, but could you explain how to use pigm?
what and where I should type to include it ?
When I unzip it indigo couldnt find textures.
sorry for my english
Posted: Thu Nov 27, 2008 9:36 am
by CTZn
Uh... that's something dougal2 did, I never used that feature... I will look at this and tell you.
The include statement can be at any place inside the <scene> tag, tho for materials you may need to include them before a mesh call them.
By the way Indigo will check for textures in a single folder you declared in MtI, really pigm is just an exchange format.
