Still using MtI 3.2.5.2
10 posts • Page 1 of 1
ior
Post by ior » Mon Jun 03, 2013 11:35 am
The problem with the world pivot is still on the versions prior than 3.2.5.2.
Recalling what does the problem do at render time:
 XYZ of world scale pivot become the XYZ values of the rotate pivot (translate), multiplied to the values XYZ of scale, plus the XYZ values of the previous world scale pivot.
Anyone with the knowledge to spot what is wrong?
It would be good to use the new things added after that version.
My endless animation works good with 3.2.5.2 thought.
ior
Re: Still using MtI 3.2.5.2
Post by ior » Wed Jul 03, 2013 8:46 am
Can anyone confirm this behavior? World scale pivot changing after render.
If so, CTZn, can you please write a script that runs, after clicking render, to make the world scale pivot equal to world rotate pivot of every scene object?
This would not really fix the thing but it would make later versions usable.
I simply do not have the knowledge to do that.
Post by CTZn » Wed Jul 03, 2013 9:36 am
fyi the procedure wich does the transform thing is mti_EM_processObj in the file mti_EM.mel (Export Modules).
You can replace it with the one of the version you want after you made a back-up.
The whole topic of catching actual objects transforms, specially constrained-locked-animated objects is also slightly above my hairs. They are not always where xform tells, I feel rather helpless.
Probably are there many more tests to do than MtI does or even did.
ior
Post by ior » Wed Jul 03, 2013 10:04 am
Thanks, Ill try that, and post the result.
Post by CTZn » Wed Jul 03, 2013 11:07 am
This procedure does not exist in earlier versions of MtI. In wich case, the procedure to replace is mti_EM_objects; it's a longer one.
You can tell because that's where you'll find the worst piece of MEL code from MtI probably: undo; undo; undo; !
ior
Post by ior » Wed Jul 03, 2013 11:14 am
in the line 386 if I replace:
	float $sclPiv[] = `xform -q -ws -sp $obj`;
with:
	float $sclPiv[] = `xform -q -os -sp $obj`;
the problem disappears! :) [EDIT]and everything seems fine
I do not know what is -os or -ws. Maybe this change makes something not to work?
ior
Post by ior » Wed Jul 03, 2013 12:00 pm
Tested in the a more complex scene and everything is fine.
Still thinking in what might be missing.
Post by CTZn » Wed Jul 03, 2013 12:14 pm
Great you fixed MtI.
I did that merging a couple days ago myself but was bothered with different things to test. Do you confirm that it is better to revert from the 3.2.5.2 obj proc ?
I may update MtI this quarter since I've been tinkering with the ISL framework a bit.
ior
Post by ior » Wed Jul 03, 2013 12:45 pm
CTZn wrote:Do you confirm that it is better to revert from the 3.2.5.2 obj proc ?
I did not do anything other than changing a letter from MtI 3.6 in mti_EM.mel file accordingly to "float $rotPiv". I do not know what -ws was doing there nor what is -os, I only know that -ws appears several times and might be doing something there, but it seems it is ok tho change the letter.
I do not know how to program I only know some basics.
Tel me what is -ws and -os.
I do not know anything about object procedure.
[EDIT]I think that if -ws or -os is not doing something specific in that line of code and if there are no new things in the new obj procedure then reverting to the old procedure might be better, but if this fix the problem with no downsides then I do not see problem in maintaining this proc.
Post by CTZn » Wed Jul 03, 2013 10:02 pm
Ah I missed your correction on the line 386.
Well the scale pivot was queried (stored) in world space and you changed the query to object space.
That was one bug indeed because the ws data was restored later as object space data, wich it is not.
My mind got totally obfuscated over the years on this topic of transforms.
