Page 1 of 2
Indigo for Cinema 4D 4.0.48
Posted: Thu Dec 22, 2016 8:12 am
by fused
Windows:
Indigo Renderer:
indigo-for-cinema-4d-4.0.48-installer.exe - Includes installers for R12 - R18
Indigo RT:
indigo-rt-for-cinema-4d-4.0.48-installer.exe - Includes installers for R12 - R18
Mac:
Indigo Renderer
indigo-for-c4d-4.0.48-R12-mac.zip
indigo-for-c4d-4.0.48-R13-mac.zip
indigo-for-c4d-4.0.48-R14-mac.zip
indigo-for-c4d-4.0.48-R15-mac.zip
indigo-for-c4d-4.0.48-R16-mac.zip
indigo-for-c4d-4.0.48-R17-mac.zip
indigo-for-c4d-4.0.48-R18-mac.zip
Indigo RT
indigo-rt-for-c4d-4.0.48-R12-mac.zip
indigo-rt-for-c4d-4.0.48-R13-mac.zip
indigo-rt-for-c4d-4.0.48-R14-mac.zip
indigo-rt-for-c4d-4.0.48-R15-mac.zip
indigo-rt-for-c4d-4.0.48-R16-mac.zip
indigo-rt-for-c4d-4.0.48-R17-mac.zip
indigo-rt-for-c4d-4.0.48-R18-mac.zip
Changelog:
* Added some options to realtime preview (halt spp, render mode, gpu).
* Invalid blend mat now exported as black diffuse material.
* Mesh export fix. Slower export, but at least it always finishes.
* Enabled stereo rendering. Careful
* Added R18 support.
* Updated sdk to 4.0.48.
* Some changes to material preview rendering.
Re: Indigo for Cinema 4D 4.0.48
Posted: Thu Dec 22, 2016 8:36 am
by Oscar J
4.0.48 and stereo rendering? Some interesting surprises in here for sure.
Posted: Thu Dec 22, 2016 8:42 am
by fused
Oscar J wrote:4.0.48 and stereo rendering? Some interesting surprises in here for sure.
C4D has built-in support for stereo rendering. Works fine, to some degree, with Indigo within C4D.
Posted: Thu Dec 22, 2016 8:55 am
by zeitmeister
Oh yeah Sir!!!!
What a Christmas Gift!
Posted: Thu Dec 22, 2016 7:53 pm
by OriginalplanĀ®
Yep. Boss level compile even for R12! Mr.fused Major League posting.
Gonna give it a try!
Posted: Sat Dec 24, 2016 1:51 am
by OriginalplanĀ®
48 feels buttery smooth! Pro work fused. THANK YOU!
Posted: Wed Dec 28, 2016 3:18 am
by Silverwing
Thanks Fused for that Christmas present. I am again surprised by the speed of Indigo. Especially the GPU!
Great work there. Keep it up!
Cheers and happy holidays!
Posted: Wed Dec 28, 2016 10:15 am
by Oscar J
Bug/annoying behaviour:
EV/ISO changes etc restarts preview render. That shouldn't be necessary?
Posted: Sun Jan 08, 2017 5:58 am
by OriginalplanĀ®
[ BUG ? ]
So when using Cindigo to render inside Cinema with two or more Light layers enabled.
Picture viewer joins together (all) the Ligh layers into one. When i go in and try to edit them inside Picture viewer/ Indigo menu.
Still has more layers present but they behave like one, produces the same effect as exporting to Indigo standalone 47.
Not sure if this is a bug or has more to do with 47 standalone still not supporting the layer system.
Anyways does not present a huge problem since IPR runs fast and recognizes Light layers.
Posted: Sun Jan 08, 2017 10:49 pm
by pixie
In gpu the layers work as opposed to standalone which is a great easter egg!
Posted: Sat Jan 14, 2017 11:28 pm
by burnin
Is support for c4d filters and procedurals/noises broken?
With R18 doesn't seem to work.
If anyone would care to check?
Or has anything drastically changed
... been long since i last dipped fingers into cinema&indigo... IIRC r15 + indigo v3... back then everything was working fine (c4d noises, layers, fusion...)
Posted: Sat Jan 14, 2017 11:47 pm
by Zom-B
burnin wrote:back then everything was working fine (c4d noises, layers, fusion...)
C4D filters always has been only backed to texture, they never had some direct procedural transition into Indigo shaders.
Baking also only works with view independent shaders like noise, but stuff like C4Ds fresnel wont work (without proper uv mapping)...
Posted: Sun Jan 15, 2017 12:40 am
by pixie
Zom-B wrote:burnin wrote:back then everything was working fine (c4d noises, layers, fusion...)
The preview was working as a charm on R15 at least
Posted: Sun Jan 15, 2017 1:27 am
by burnin
Yeah, that much i know
Still...
... OK, plugin is bugged:
- with 4.0.48
- with 3.8.26.2
- with 3.8.12
PS: for previews doesn't work on R18
Posted: Sun Jan 15, 2017 2:42 am
by Zom-B
Yes, just tested in R18 Demo. While its all good in R17, for R18 baking fails.
On export Indigo gives this material error:
Failed to find texture 'C:\Users\zom_b\AppData\Roaming\Indigo for Cinema 4D\quickrender\shader-could-not-be-baked.png', used by material 'apple'.
