lost newbie
lost newbie
This is the first time I use an external renderer. Never tried VRay, Maxwell or Octane.
Installation is very simple (mac user) and renders are easy to do in the c4d picture viewer but there is a point that I don't understand : why I've installed 2 softwares Indigo and Indigo RT. What is the use of Indigo RT ? Is it just a "poor" license or a software with another functions ? What means RT ? Real Time ? Like Octane.
It's very confuse for me.
I've noticed that we can't assign several materials on same polygons. I work for watchmaking industry and I always have 2 shaders : one for background (brushed silver for example) and one for printing.
Despite of these questions, Indigo is very fast and metals are incredibly realistics !
C4D 15 studio - MOI3D - France
Re: lost newbie
http://www.indigorenderer.com/product-comparison
Indigo RT is a version with some limitations but a lovly pricetag.
Both version work the same way besides this restrictions for the RT version
Re: lost newbie
Ok, I've changed the path in my prefs (indigo > indigo RT). Works similar.
I've noticed that render never stops like C4D PhysicalRender Progressive mode. Can we force it to stop with a preset ?
Re: lost newbie
Hi lenogre, Indigo has this material called 'blend', wich allows to mix two materials according to a 'mask' (blend) texture, like fonts for instance. Since blend materials can also be blended together, there is virtually no limits on the number of materials per triangle.lenogre wrote:I've noticed that we can't assign several materials on same polygons. I work for watchmaking industry and I always have 2 shaders : one for background (brushed silver for example) and one for printing.
Re: lost newbie
Hi lenogre,lenogre wrote:Ok, I've changed the path in my prefs (indigo > indigo RT). Works similar.
there are the halt time (seconds) and halt spp (samples per pixel) settings which you can use to control when the render stops.
Regards,
Yves
Re: lost newbie
Default settings :
halt time -1
halt samples per pixel -1
When I'm doing a render, I can see Rendering : XX.X s/px. I would like control XX.X
Default settings are incomprehensible for me.
halt time -1
Re: lost newbie
Hi all, for my first post !
Hello Lenogre, nice to see you here, and again > FrenchC4D
First stop your render, go to Render Settings et put what you want in Halt time or Halt SSP.
Start rendering, it will stop on your choice.
There is a french section in Language forum :
http://www.indigorenderer.com/forum/vie ... =15&t=1313
Re: lost newbie
Ok, verstanden.
Negative values never stop rendering. Renderings begin at 0...
- Polinalkrimizei
Re: lost newbie
Halt time sind Sekunden, und mit den samples per pixel musst Du je nach Szene eben etwas experimentieren. Oft ist 2000 schon ok, aber je komplexer oder "shinier" Deine Materialien sind, desto mehr spp dauert es, bis der Render wirklich sauber aussieht. Wenn man viele ähnliche Bilder macht, ist das sehr sinnvoll, oder wenn man verhindern will, dass die Stromrechnung über Nacht explodiert (kommt auch auf den/die Rechner an).
Re: lost newbie
Ho compreso (via Reverso)... I mean, despite the use of an german word there's a good chance that lenogre can not speak it ! Wait and see; oder was bitte excusieren Sie mich (ok I for one tried ).
Je fais partie des français qui pourraient vous répondre au sujet d'Indigo en général dans le forum dédié (je ne suis pas un utilisateur de C4D).
Ciao !
Ciao !
- Polinalkrimizei
Re: lost newbie
Hahaha sorry for the german spam couldn't help it!
Re: lost newbie
no way, that was a natural thing to do polinalkrimizei, it's me bugging around sorry guys I'm out here
Re: lost newbie
I don't speak german. I've learned it when I was 11 years old. I've almost all forgotten...
Well, I continue my exploration. I've downloaded some materials. Half ones are in .pigm and others in igm.xml.
I've seen some terrific code lines (puke !). I don't want to be a programmer, I can do some Xpresso but not this.
About xml, I suppose we can copy/paste but it's a bit confuse for me.
I've noticed that SLA shaders are not converted (what a surprise !) and I'm looking for good anisotropic materials. Many materials in the database are quasi all in xml. I don't how configure them.
Material thumbnails are very, very dark. Not easy to find the good one. We can change the shape but it's not a good point.
Re: lost newbie
1/ Pictures are rendering in the c4d picture viewer.
Is there a benefit to render pictures in Indigo interface ?
2/ About NK (IOR). Lot of values. Some are easy to understand (Al, Au, Cu, Diam) but most have no signification for me. Is there a translation for that ?
