Page 1 of 1
Indigo for Cinema 4D 3.6.9 Beta
Posted: Wed Mar 13, 2013 3:15 am
by fused
for Indigo Renderer 3.6.9 and Indigo RT 3.6.9
Windows:
Indigo Renderer:
indigo-for-cinema-4d-3.6.9-installer.exe - Includes installers for R10 - R13 (R12 and R13 versions both work with R14)
Indigo RT:
indigo-rt-for-cinema-4d-3.6.9-installer.exe - Includes installers for R10 - R13 (R12 and R13 versions both work with R14)
Mac:
Indigo Renderer
indigo-for-c4d-3.6.9-R105-mac.zip
indigo-for-c4d-3.6.9-R11-mac.zip
indigo-for-c4d-3.6.9-R115-mac.zip
indigo-for-c4d-3.6.9-R12-mac.zip
indigo-for-c4d-3.6.9-R13-mac.zip
Indigo RT
indigo-rt-for-c4d-3.6.9-R105-mac.zip
indigo-rt-for-c4d-3.6.9-R11-mac.zip
indigo-rt-for-c4d-3.6.9-R115-mac.zip
indigo-rt-for-c4d-3.6.9-R12-mac.zip
indigo-rt-for-c4d-3.6.9-R13-mac.zip
Changelog:
* Added shadow and depth pass.
* Added "Shadow Catcher" checkbox to "Extra Options" in the Indigo Material.
* Added Indigo Compositing Tag.
* Added support for invisible to camera.
* Added preview quality options "Off" and "Ultra".
* Added option to share a medium with another material (experimental).
* Added a few more Indigo material preview scenes.
* Added ISL normal shader (experimental, will change).
* Fixed problems with textures in preview scenes.
* using Indigo 3.6.9 SDK.
Re: Indigo for Cinema 4D 3.6.9 Beta
Posted: Wed Mar 13, 2013 3:17 am
by fused
There is a know issue with R13 and possibly R14 that the alpha channel (when rendering foreground alpha or using the shadow pass) will not be saved by C4D.
Posted: Wed Mar 13, 2013 3:43 am
by CTZn
fused wrote:* Added support for invisible to camera.
Hah. Clearance rank 3 pending :P
edit: ah no hold on... pixiiiiiiie heeeeelp !!!!!
edit2: all good now, you owe me one pixie though ;)
Good job I assume !
Posted: Wed Mar 13, 2013 3:51 am
by wlf_alex
Fantastic ! Thanks а lot ! :)
Posted: Wed Mar 13, 2013 3:54 am
by ritter
Thank you ! :D
Posted: Wed Mar 13, 2013 6:11 am
by pixie
Good job I assume !
Pixie is here for the rescue! xD Sadly Pixie couldn't make it work.
PS. Pixie's desire was just to click on the red 'visible in editor' and make it simply work. Nor the tag applied on the scene.
P.S.S It works inside the Cinema 4D, bummer!
Posted: Wed Mar 13, 2013 6:36 am
by zeitmeister
Very cool, thank you Yves!!!
Posted: Wed Mar 13, 2013 7:17 am
by CTZn
pixie wrote:Pixie is here for the rescue! xD Sadly Pixie couldn't make it work.
There was only the API method implemented in Indigo 3.6.9 for invisible_to_camera support I'm guessing.
Cheers
Posted: Sun Mar 17, 2013 8:04 am
by Ilay
Hello Yves
Can post image or sample?
Posted: Mon Mar 18, 2013 1:14 am
by Zom-B
Ilay wrote:Hello Yves
In the Medium Section of a material on the top you have that field wehere to drag & drop the material to share the medium with!
This is needed for some setups where you have for example one glass object, but with one side of it a frosted glass (using a glossy transparent material). Such glass object would need to have the same medium for both materials to render correctly :)
Posted: Mon Mar 18, 2013 4:24 am
by Ilay
Thanks Arthur .... Спасибо.
Honestly i don't understand. Can you show, if it will be possible by schema?
Posted: Mon Mar 18, 2013 4:59 am
by Zom-B
Here a scene that should show how to use this shared medium thing. You see that the own medium of the "Frosted Glass" is getting ignored (green) since its now using the medium of the "Glass" material (red).
Posted: Mon Mar 18, 2013 5:02 am
by Ilay
Thank you, cool feature.
Posted: Mon Mar 18, 2013 10:16 pm
by pzdm
oooh, it looks amazing..
btw, works the shadows pass well (inside the C4D?) And the same for mt ID pass, colors were very close together (all green). I have tested the same in Stand alone version, there are not problems...
Many thanks for a reply, Pavel
Posted: Mon Mar 25, 2013 2:26 am
by kklors
Awesome!
Haven't had the opportunity to test it properly yet, but I think all the recent betas got a bug where you would lose resolution and the image get's a weird 1:1 squish once you apply a Layer shader to any Indigo material. I first noticed it with 3.6.6 or 3.6.7 onwards I think.
