Indigo Renderer 4.6.4 Release
Re: Indigo Renderer 4.6.4 Release
Found BUG in version 4.6.4 (not present in version 4.6.0) only in OpenCL mode
The background overwrites all (see attachments)
Not present in 4.6.4 (BiDir mode) or 4.6.0 (BiDir or OpenCL)
Looking at the number of samples/sec in the two cases, it's as if it doesn't render anything except the background....
A. Delle
A. Delle
The same Project (Indigo 4.6.4) sometimes causes "Out of resource" error on my videocard (NVIDIA GeForce RTX 3060 Laptop GPU).
Error: Exception while advancing OpenCL PT on device 'NVIDIA GeForce RTX 3060 Laptop GPU': clEnqueueReadBuffer failed: CL_OUT_OF_RESOURCES
Indigo 4.6.0 renders correctly
( you can download the IGS project from here >>> https://we.tl/t-h9dPVcsJ3C )
I've the same problem...easyarchitect wrote: ↑Fri Sep 16, 2022 12:29 amFound BUG in version 4.6.4 (not present in version 4.6.0) only in OpenCL mode
A. Delle
Thanks for keeping it going Ono!
Not sure its the exporter or Indigo, but something seems horribly broken when GPU rendering on my system:
Another older scene renders fine, yet another one after the first "flash" of an image, it only renders the environment HDRI.Re: Indigo Renderer 4.6.4 Release
Thanks for this update, I'm glad Indigo is alive. Please keep that way, subscription based if needed.
Yeah have found + fixed this bug, will make new build soon.Headroom wrote: ↑Sat Oct 01, 2022 1:28 pmNot sure its the exporter or Indigo, but something seems horribly broken when GPU rendering on my system:
@OnoSendai Awesome, thank you!
In the meantime the updated Blendigo also works with 4.6.9.
hi, very strange behaviour: the same scene, the same rig (5x 2070/2060s) but:
- cindigo 4.4.13 - 660 samples / sec
- indigo standalone 4.6.4 (and 4.6.0 too) - 550 samples / sec (exported from cinema 4d thru cindigo 4.4.13)
nvidia driver 517.48
gpu utilization of cindigo (left) and standalone (right), the same scene:
p.s. but it has the same samples/sec with single primary GPU - cindigo and standalone (2 gpus or more - different)
https://www.indigorenderer.com/materials/materials/273
This material crash
https://www.indigorenderer.com/materials/materials/1337
This material very slow speed render mode BiMtl
Sometimes (Random) it helps to switch the parameter _ Number of values: 301 fast double click to 299 and to back 301
Proof video bug 300 to 301 black dots
This material crash
- bug_light_indigo.zip
- (4.02 MiB) Downloaded 199 times
This is very encouraging. I am looking for the best alternative to Maxwell render and Indigo seems a good fit.
Some things that are important for me to switch or to add Indigo alongside Maxwell....
The most important for now is using NK/IOR files seems more difficult than I would like. I don't understand why there is not a standard file requester to load the data, or why adding additional data requires overwriting NK files in the application folder. More detailed documentation about this would be useful.
Clear signs of development activity is important and a big part of why I am looking for alternatives to Maxwell Render.
Unusable. Is this being checked for bugs before its put out there? Within 2 minutes of trying to use it, something falls apart.
@ErichBoehm
This is a beta release for those who wish to help the developer find and fix bugs and try out newer features. For the latest official stable release you should go here:
https://www.indigorenderer.com/download-indigo-renderer
Either way your comment doesn't do anything to help anyone, yourself included, solve whatever issues you're facing. There are some great, and very talented, people on the forum that might be able to help if they knew what the issue is. Also the developer can't fix bugs he's not got any actionable info on.
- pixie
It is the best, no doubt about it!
4.6.0 beta is usableErichBoehm wrote: ↑Wed Oct 19, 2022 4:54 amUnusable. Is this being checked for bugs before its put out there? Within 2 minutes of trying to use it, something falls apart.
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 145 guests
