Page 1 of 4
0.9 test 8 Linux build (32 and 64 bit)
Posted: Wed Oct 17, 2007 4:20 am
by OnoSendai
For those lucky people with a 64 bit CPU,
and those running 64-bit linux,
here is a native linux x64 build of indigo.
http://www.indigorenderer.com/joomla/in ... &Itemid=62
Only indigo_console is built, no GUI executable for now.
Apart from that everything should work, hopefully.
You'll probably need to install OpenEXR.
EDIT:
32 bit native linux build:
Posted: Wed Oct 17, 2007 4:35 am
by Phr0stByte
YIPEE!!!
Thanks Ono!
Posted: Wed Oct 17, 2007 5:57 am
by zsouthboy
Ono:
I have attached the last bit of the logfile from that huge render i've been running - something "funny" happens - 9000 seconds for the last save?!?!
Also, network rendering does not work. The master never responds to the slave - the slave appears to work correctly however.
Display took 970.21312 s
Time elapsed: 34 h, 49 m, 40 s
Done 9771880000.00000 samples (130.29173 samples per pixel)
77938.06141 samples / second (12.83070 micro-seconds / sample)
saving tone-mapped image to 'renders/im1192340722.png'
done.
Display took 647.10712 s
Time elapsed: 35 h, 5 m, 28 s
Done 9792940000.00000 samples (130.57253 samples per pixel)
77519.59929 samples / second (12.89996 micro-seconds / sample)
done.
Display took 588.97291 s
Time elapsed: 35 h, 20 m, 18 s
Done 9922280000.00000 samples (132.29707 samples per pixel)
77994.15153 samples / second (12.82147 micro-seconds / sample)
done.
Display took 2974.17293 s
Time elapsed: 36 h, 14 m, 53 s
Done 10106210000.00000 samples (134.74947 samples per pixel)
77446.32439 samples / second (12.91217 micro-seconds / sample)
done.
Display took 1229.97404 s
Time elapsed: 36 h, 40 m, 24 s
Done 10260650000.00000 samples (136.80867 samples per pixel)
77717.98723 samples / second (12.86703 micro-seconds / sample)
done.
Display took 1442.23909 s
Time elapsed: 37 h, 9 m, 27 s
Done 10415070000.00000 samples (138.86760 samples per pixel)
77859.42538 samples / second (12.84366 micro-seconds / sample)
done.
Display took 1246.82453 s
Time elapsed: 37 h, 35 m, 15 s
Done 10583200000.00000 samples (141.10933 samples per pixel)
78211.16642 samples / second (12.78590 micro-seconds / sample)
done.
Display took 1030.60997 s
Time elapsed: 37 h, 57 m, 27 s
Done 10709230000.00000 samples (142.78973 samples per pixel)
78371.33161 samples / second (12.75977 micro-seconds / sample)
done.
Display took 641.95445 s
Time elapsed: 38 h, 13 m, 10 s
Done 10830030000.00000 samples (144.40040 samples per pixel)
78712.06629 samples / second (12.70453 micro-seconds / sample)
done.
Display took 1343.35965 s
Time elapsed: 38 h, 40 m, 34 s
Done 10971700000.00000 samples (146.28933 samples per pixel)
78800.01351 samples / second (12.69035 micro-seconds / sample)
done.
Display took 843.79402 s
Time elapsed: 38 h, 59 m, 39 s
Done 11021970000.00000 samples (146.95960 samples per pixel)
78515.46565 samples / second (12.73634 micro-seconds / sample)
done.
Display took 596.06805 s
Time elapsed: 39 h, 14 m, 36 s
Done 11046480000.00000 samples (147.28640 samples per pixel)
78190.28676 samples / second (12.78931 micro-seconds / sample)
done.
Display took 497.35909 s
Time elapsed: 39 h, 27 m, 55 s
Done 11163480000.00000 samples (148.84640 samples per pixel)
78574.28580 samples / second (12.72681 micro-seconds / sample)
done.
Display took 978.13680 s
Time elapsed: 39 h, 49 m, 14 s
Done 11213780000.00000 samples (149.51707 samples per pixel)
78224.25187 samples / second (12.78376 micro-seconds / sample)
done.
Display took 9294.99848 s
Time elapsed: 42 h, 29 m, 11 s
Done 12172080000.00000 samples (162.29440 samples per pixel)
79581.40846 samples / second (12.56575 micro-seconds / sample)
done.
Display took 8597.22435 s
Time elapsed: 44 h, 57 m, 29 s
Done 13391630000.00000 samples (178.55507 samples per pixel)
82741.34038 samples / second (12.08586 micro-seconds / sample)
done.
Display took 7826.04191 s
Time elapsed: 47 h, 12 m, 56 s
Done 14466630000.00000 samples (192.88840 samples per pixel)
85109.68922 samples / second (11.74954 micro-seconds / sample)
done.
Display took 6004.44275 s
Time elapsed: 48 h, 58 m, 1 s
Done 15241440000.00000 samples (203.21920 samples per pixel)
86460.85344 samples / second (11.56593 micro-seconds / sample)
done.
Display took 8060.41707 s
Time elapsed: 51 h, 17 m, 22 s
Done 16460110000.00000 samples (219.46813 samples per pixel)
89145.85940 samples / second (11.21757 micro-seconds / sample)
done.
Display took 5705.40396 s
Time elapsed: 52 h, 57 m, 28 s
Done 17205160000.00000 samples (229.40213 samples per pixel)
90245.42153 samples / second (11.08089 micro-seconds / sample)
done.
Display took 9328.80546 s
Time elapsed: 55 h, 37 m, 58 s
Done 18564420000.00000 samples (247.52560 samples per pixel)
92693.11566 samples / second (10.78829 micro-seconds / sample)
haxor@quadLOL:~/Desktop/indigo_x64_linux_v09_test8_1$
Posted: Wed Oct 17, 2007 6:04 am
by dougal2
zsb: pfft at your name+machine name ;)
Posted: Wed Oct 17, 2007 6:13 am
by zsouthboy
dougal2 wrote:zsb: pfft at your name+machine name ;)
I always get a kick out of other peoples replies to that.
quadLOL was an appropriate name for this particular box, though. :P
Posted: Wed Oct 17, 2007 6:21 am
by Macrob
The same here.
Still got the exr problems with 64 and 32 bit and openexr 1.4a and 1.6
Posted: Wed Oct 17, 2007 6:39 am
by Phr0stByte
Macrob
can you open an exr with:
exrdisplay path/to/image
(test to see if this is an exr issue, or Indigo)
Posted: Wed Oct 17, 2007 7:12 am
by Macrob
Phr0stByte wrote:Macrob
yes :roll:
Posted: Wed Oct 17, 2007 7:23 am
by Genscher
Hello,
just tested thew 64bit build on Fedora 7.
Some problems appeared with missing liberies of OpenEXR 1.2 but creating symlinks from OpenEXR 1.4 libs worked fine then.
Greetings and good work!
UPDATE:
If anyone is interested in a new Blendigo exporter which works with the linux builds, here we go:
http://www.indigorenderer.com/joomla/fo ... &start=255
Posted: Wed Oct 17, 2007 7:40 am
by manitwo
big THANKS for a linux build ono :!:
Posted: Wed Oct 17, 2007 8:06 am
by joegiampaoli
Ono! Thx man! This is absolutely great. :D
It's working good here at 32 bit on my side.
Maybe just my imagination, does it eat more memory than wined? Can someone help me confirm this?
Aside from that, just Great!
EDIT: Ah no resume? Doesn't seem to resume..... :cry:
Posted: Wed Oct 17, 2007 9:26 am
by Phr0stByte
x64 working great here
Aut-thread detection working, as well as exr support
Posted: Wed Oct 17, 2007 10:15 am
by vux
Ono can you aswer me?:
what optimization flags did you use for gcc?
and meybe you need to try Intel C Compliler?
Posted: Wed Oct 17, 2007 10:19 am
by Genscher
@ vux:
1. Why Iintel C compiler? GCC is fine.
2. You also have to know that he normaly can't to too much optimizing because all people want to use it. So if he enabled SSE or something, there are always people crying up "that build doesn't work".
Thanks.
Genscher
Posted: Wed Oct 17, 2007 10:26 am
by vux
"2. You also have to know that he normaly can't to too much optimizing because all people want to use it. So if he enabled SSE or something, there are always people crying up "that build doesn't work"."
I know that. But maybe need to build and share few variants of compile.
If used ICC Indigo may work faster.
I think its interest for many ppl.
