Slaves don't need to save images, no.mrCarnivore wrote:Prompts are really awkward, when you want to do batch rendering (as can be the case with network rendering). So I would suggest only a warning message if there is absolutely no output defined and the image doesn't act as a slave.CTZn wrote:In that case a prompt would be usefull, in the case where you are not saving any image (by mistake).
BTW: Do rendering slaves need to save images or can they just send them through the network?
Indigo 0.9 test 6
- Heavily Tessellated
Don't sweat it, we're linux geeks.OnoSendai wrote:Windows doesn't mind if I put the CRT dlls in the Microsoft.VC80.CRT folder, and it's a bit neater so I did that. If Wine doesn't like it however, I'll just move them up into the indigo directory.
[heavily@renderslave indigo_v09_test6]$ for file in Microsoft.VC80.CRT/*;do ln -s $(basename $file) $file;done
takes care of that. File locations are the least of our issues re: Indigo and wine...
So a native version, hmm? No teasing! How serious are you?
