Indigo 0.8 stable
Posted: Wed May 16, 2007 2:18 am
Well, it was time to get 0.8 out of the way. So here's 0.8 stable.
(I'm calling it stable instead of final in case I want to bugfix it
The big changes in 0.8 are the BIH, hybrid mode, and RQMC stuff, plus the
new diffuse transmitter material and working normals for the blend material
http://www2.indigorenderer.com/joomla/i ... &Itemid=62
Total v0.8 changelog:
0.8 stable
* fixed small error in colour space conversion stuff
* sped up the RGB->spectrum code
* updated manual
0.8 test 3
* added blended shading normal for blend material (fixes bump for blend mat)
* fixed null material
* fixed bump mapping with bidir, messed around with shading stuff
* changed default burn to 10
* added diffuse transmitter material
0.8 test 2
* fix for crash/error with phong mat
0.8 test 1
* Added hybrid mode
* added hybrid setting in inifile.
* Added BIH tree acceleration type.
* Added bih_tri_threshold to inifile.
* using ijg jpeg lib instead of intel jpeg lib.
* added /fixed:no to link input
* cleaned up log format a little bit
* added camera glare
* improved triangle sampling
* fix for normal calc in light sampling pdf calcs
* added energy loss compensation for phong BSDF
0.8 stable
* updated manual
0.8 test 3
0.8 test 2
0.8 test 1
* Added hybrid mode
