Page 1 of 1
Indigo Renderer 4.0.53 Beta Release
Posted: Fri May 26, 2017 12:33 am
by OnoSendai
This is a Beta release.
Indigo for Windows 64-bit:
IndigoRenderer_x64_4.0.53_Setup.exe
Indigo for Linux 64-bit:
IndigoRenderer_x64_v4.0.53.tar.gz
IndigoRenderer4.0.53.dmg
Indigo RT for Windows 64-bit:
IndigoRT_x64_4.0.53_Setup.exe
Indigo RT for Linux 64-bit:
IndigoRT_x64_v4.0.53.tar.gz
IndigoRT4.0.53.dmg
Changelog:
4.0.53
* Fixed crash with orthographic camera and bidir.
* Improved speed of bidir a little.
* Added support for orthographic cameras back to the OpenGL preview.
* Fixed crash when rendering material previews with the non-default scene.
* Fixed object picking sometimes picking the wrong object.
* Changed minimum JPEG quality to 75.
* Fixed --tonemap not working properly.
Re: Indigo Renderer 4.0.53 Beta Release
Posted: Sat May 27, 2017 7:48 pm
by OriginalplanĀ®
Posted: Sun May 28, 2017 1:52 am
by bubs
Is there an issue here with 'assign material'? I don't seem to be able to change materials within the render...
Posted: Sun May 28, 2017 2:23 am
by OnoSendai
bubs wrote:Is there an issue here with 'assign material'? I don't seem to be able to change materials within the render...
It's entirely possible I broke some aspect of that, was changing that stuff. However it seems to work here for me. Can you email us a PIGS showing the problem with instructions on how to replicate the issue?
Thanks,
Nick
Posted: Mon May 29, 2017 2:23 am
by burnin
Hm... IDK... glitches or bugs? ;)
- can't resize the graph in spectrum editor (editor itself can be resized)
- when hovering over rendered image, 1 pixel frame is shown around and it feels as bleeding into the rendered image, very distracting
Refreshing problems:
- clamping is non consistent dependent on Tone Mapping Method, Render Engine & using either CPU or GPU rendering
- updating rendered image render often times doesn't work as expected - i.e. often times only starts rendering again while everything else stays same
- often times fresnel glitches, switching engines or processing unit resolves an issue
&BTW (OT) :)
Blender exporter has become painful to use in comparison to other exporters (corona, lux, prman): no development since v3 days, no preview whatsoever, long export times... forces user/artist to have strong mental visualization capabilities (old school) tho, as of late clients get extremely fast sick of words & promises, they admire only images, real-time view is as is light to a moth - since the engine is extremely fast (+ spectral), thus lacking previews (good Blender integration) is very efficient turnoff. Neither there's a Houdini exporter.
Otherwise great work on the engine, wish i could join the challenge but these issues have diminished my motivation (similar to what maxwell did with v4, stayed on v3 & rarely used it in the past year).
no hard feelings, just my personal opinion
EDIT:
Been long out, so after some more fiddling, finally got a bit of a grip back :D
- Blue frame/border line is really distracting, especially on dark UI - maybe toggle ON/OFF or color selection
- another distraction is happening when scrolling up & down, accidentally landing on value input changes the value, thus running render from start
- can't "," on numerical keyboard be used as a comma?
- is it impossible to copy/paste textures & colors over different slots/channels?
- drop down menu UI approach is becoming time consuming (option for tabs or floating windows maybe?)
- any way to get scene file stats (sizes, unit effeciency, mem. consumption...) to show somewhere (not the console)? Found it - under Render Settings facepalm
- camera vignette settings are not in the Studio?
- are you considering on implementing denoiser?
None the less, amazing... got the motivation back, thank you!
:D
Posted: Mon May 29, 2017 8:40 am
by Oscar J
burnin: The blue border is normally not there. Probably you've enabled region render somewhere, possibly you have a border in blender before export?
Posted: Mon May 29, 2017 9:54 am
by burnin
Oscar J wrote:burnin: The blue border is normally not there. Probably you've enabled region render somewhere, possibly you have a border in blender before export?
Oh... :) true that, i have border always checked in blender (for camera preview sake).
Thank you for that precious little info! :D
Posted: Mon May 29, 2017 7:54 pm
by Pibuz
I have a little suggestion to give: could be VERY useful to have the specification of the plugin release number in the Indigo installer main window, so we can check if we already have an up-to-date version already installed.
Posted: Wed May 31, 2017 1:10 am
by OnoSendai
Pibuz wrote:I have a little suggestion to give: could be VERY useful to have the specification of the plugin release number in the Indigo installer main window, so we can check if we already have an up-to-date version already installed.
You can check the Indigo version you have installed by opening the about dialog: Help > About.
Or do you mean something else?
Posted: Wed May 31, 2017 2:27 am
by Pibuz
Hi Ono! I meant: explicitate the PLUGIN version embedded in the main Indigo installer, where you have all the checks. This way we can always aware of which version of the plugin (say Skindigo) we are installing automatically with the Indigo installer, so we can directly uncheck the installation if we already installed a version (even an updated version).
Posted: Wed May 31, 2017 3:23 am
by zeitmeister
Very nice!
It's so lightning fast...
One thing I don't understand: Why is it not possible to force updating image via button in GPU mode?
Posted: Wed May 31, 2017 3:26 am
by OnoSendai
zeitmeister wrote:Very nice!
GPU rendering does a complete 'render pass' before it can show something new.
Or do you mean with network rendering?
Posted: Wed May 31, 2017 3:33 am
by OnoSendai
Pibuz wrote:Hi Ono! I meant: explicitate the PLUGIN version embedded in the main Indigo installer, where you have all the checks. This way we can always aware of which version of the plugin (say Skindigo) we are installing automatically with the Indigo installer, so we can directly uncheck the installation if we already installed a version (even an updated version).
Ah I see, that's a good idea.
Posted: Wed May 31, 2017 5:20 pm
by zeitmeister
No, that's what I meant. Thank you for clearence!
