Page 1 of 2
Indigo Renderer 3.4.17
Posted: Fri Nov 23, 2012 1:23 am
by fused
This is a bugfix release.
Indigo for Windows 32-bit:
IndigoRenderer_3.4.17_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_3.4.17_Setup.exe
Indigo for Linux 32-bit:
IndigoRenderer_v3.4.17.tar.gz
Indigo for Linux 64-bit:
IndigoRenderer_x64_v3.4.17.tar.gz
IndigoRenderer3.4.17.dmg
Indigo RT for Windows 32-bit:
IndigoRT_3.4.17_Setup.exe
Indigo RT for Windows 64-bit:
IndigoRT_x64_3.4.17_Setup.exe
Indigo RT for Linux 32-bit:
IndigoRT_v3.4.17.tar.gz
Indigo RT for Linux 64-bit:
IndigoRT_x64_v3.4.17.tar.gz
IndigoRT3.4.17.dmg
Changelog:
3.4.17
* Fixed Windows side-by-side configuration problems.
* Fix for bidir and participating media.
Re: Indigo Renderer 3.4.17
Posted: Fri Nov 23, 2012 2:37 am
by pixie
Look! That cloud seems as if it is really smilling! :D
Posted: Fri Nov 23, 2012 3:20 am
by noldo
Even with this version I can not open the .igi files.
As soon as I try to open a .igi file, the program crashes.
(indigo rt 64 bit - Windows vista)
Posted: Fri Nov 23, 2012 4:22 am
by Juju
so soon! thanks.
Posted: Fri Nov 23, 2012 4:31 am
by CTZn
What was it with bidir and participating media ?
Posted: Fri Nov 23, 2012 11:07 am
by OnoSendai
CTZn wrote:What was it with bidir and participating media ?
Was missing a term in the PDF calculations in one place.
Posted: Fri Nov 23, 2012 11:25 am
by CTZn
Like a tooth missing.
I'm wondering wether the issue where bidir connections are not made between media of IOR 1.0 is also considered as a bug.
Posted: Fri Nov 23, 2012 11:27 am
by OnoSendai
CTZn wrote:Like a tooth missing.
It's not considered a bug because it converges to the correct result. It's just sub-optimal.
Posted: Fri Nov 23, 2012 5:52 pm
by CTZn
Ok. I must precise that this issue concerns the anyway peculiar case of custom air to air media interface.
Posted: Thu Nov 29, 2012 6:06 pm
by littlemissbridget
Been trying to render a parallel projection. It exports, but then errors once indigo renderer opens.
Error reads "Error: Scene parsing error: Found unexpected element 'camera_type'. (In element 'camera', around line 43, column 9)"
Posted: Thu Nov 29, 2012 7:17 pm
by Zom-B
littlemissbridget wrote:Been trying to render a parallel projection. It exports, but then errors once indigo renderer opens.
Rule No1 if you encounter some problem: Keep you Exporter and Indigo version up to date!
There is a
good chance that your problem results in version incompatibilities, or the bug is already fixed...
You are using a old Indigo version that don't support the new camera type introduced in 3.4.4
Posted: Thu Nov 29, 2012 7:59 pm
I thought I just updated both today? will check
Posted: Thu Nov 29, 2012 8:21 pm
by Zom-B
littlemissbridget wrote:I thought I just updated both today? will check
If you work with C4D Exporter for example there is a path in the Program Settings to assign the folder for Indigo, it doesn't get read out of the System Registry since some versions! Maybe the problem is related to the autostart from Exporter :)
Posted: Thu Nov 29, 2012 8:34 pm
oh gosh i downloaded it but did not install. works just fine.
sorry been working long hours (graduating university in a week if i complete these renderings)...thank you for your help!
Posted: Thu Nov 29, 2012 8:39 pm
by Zom-B
No problem at all, enjoy the updated version :)
