Page 1 of 3
Indigo Renderer 3.2.5
Posted: Wed Dec 14, 2011 1:40 am
by fused
This is a Beta release.
Indigo for Windows 32-bit:
IndigoRenderer_3.2.5_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_3.2.5_Setup.exe
IndigoRenderer3.2.5.dmg
Indigo RT for Windows 32-bit:
IndigoRT_3.2.5_Setup.exe
Indigo RT for Windows 64-bit:
IndigoRT_x64_3.2.5_Setup.exe
IndigoRT3.2.5.dmg
Changelog:
3.2.5
* Alpha tracer now traces through partial null blends.
* Fixed darkening of the image when alpha or material id tracer are used with a generated aperture.
* Added reporting of CUDA and OpenCL driver version(s)
* Options dialog now warns when using "localhost" as the hostname for the Network Manager.
* When opening a material that has displacement, subdivision is added the the preview mesh.
* Fixed: When rendering with GPU acceleration and stopping, render times and SPS stats still keep updating.
* Fixed obstacle map loading for aperture diffraction.
* Fixed disappearing Render Settings widget.
* Greatly improved message handling overhead in realtime mode.
* Resolved minor GPU acceleration performance regression.
Re: Indigo Renderer 3.2.5
Posted: Wed Dec 14, 2011 10:40 pm
by Pibuz
I get the attached message.
It shows since 3.2.4 release.
3.2.3 works allright :)
Posted: Thu Dec 15, 2011 1:28 am
by lycium
Hi Pibuz, I'm afraid you'll have to update your drivers again: http://www.nvidia.com/drivers
The 285.62 certified drivers from October work great :)
Posted: Thu Dec 15, 2011 1:55 am
by Pibuz
Hi Thom.
I was quite sure I had a quite updated drivers configuration, but you were right (as always): I had 276.14, and the current is 276.28 (I'm referring to nVidia QUADRO 4000 drivers).
Once updated, the error still appears.
Posted: Thu Dec 15, 2011 2:52 am
by lycium
Interestingly the latest Quadro drivers don't support CUDA 4.1, even though they are of the correct version number and very recent etc.
Sorry for this inconvenience and thanks for reporting, we'll revert to 4.0 for now.
Posted: Sat Dec 17, 2011 3:41 am
by dougal2
BiDir + MLT is broken ?
I tried to render a simple test scene and it said 0 s/s despite using all cores.
EDIT: appears to be related to using an SSS material.
Posted: Sat Dec 17, 2011 5:05 am
by lycium
SSS materials can induce a very high number of scatters, which makes the MLT warmup take a loooong time. There's also a case where it can become essentially stuck, this is known and will be fixed relatively soon (it's on our TODO towards the top!).
Posted: Mon Dec 19, 2011 9:58 pm
by Zom-B
If you trigger image overlay options during rendertime, the "Time elapse" counter resets to Zero...
There is a very ugly bug regarding EP and Glass material (rendertime varies!):
EP activated in BiDirPT:
No EP in BiDirPT:
EP activated in BiDirMLT:
No EP in BiDirMLT:
For me it looks liuke behind the glass you only see sky light but not direct Sunlight in PT mode, same as the Bug reported before GPU + EP.
Any thoughts here guys? I used the old Sky Model and no, Glass Acel. doesn't help here :(
** EDIT **
Attached Szenefile
EP Bug.pigs
(2.79 KiB) Downloaded 361 times
Posted: Mon Dec 19, 2011 10:09 pm
by Zom-B
I also did a quick test with that scene using a EnvMap,
here you have a small shift ind the EnvMap, but no actual rendering issues:
EP active:
Ep off:
Posted: Mon Dec 19, 2011 10:19 pm
by dcm
Arthur, you are great reminder. Thanks, i posted this few months back and i hope this will be fixed soon.
Posted: Mon Dec 19, 2011 11:03 pm
by OnoSendai
Hi Zom-B,
Thanks for the report.
It's not actually a bug, just the same old slow-to-converge behaviour with some kind of paths.
I do have some plans to fix this.
Posted: Mon Dec 19, 2011 11:17 pm
by pixie
What's an EP?
Posted: Mon Dec 19, 2011 11:26 pm
by Pibuz
Exit Portal I guess.
Took me some time to figure it out too :D
Posted: Wed Dec 21, 2011 12:13 am
by dcm
OnoSendai wrote:Hi Zom-B,
I found this "bug" at begninning of summer as far as i remember and i did some tests. One of them was rendertime. 48hours on 2 computers and sun wasnt visible behind the glass. Without EP, sun is visible immediately.
Posted: Wed Dec 21, 2011 10:01 pm
by Zom-B
It seems that GPU rendering has a general darker phong material then CPU based rendering:
CPU:
GPU:
Something that can be fixed?
