Log in or Register.
Download Trial Buy now
After SkIndigo has been installed, a small toolbar is added to the SketchUp user interface for easy access to commonly used export functionality from the menu, in addition to a "Quick Export" button:
Render with Indigo
Export the SketchUp scene to Indigo format and start rendering it in Indigo.
Quick Export
Use this option after you have finished modelling and applying materials to your model. You must have exported your scene at least once before you can use this option. This option will not re-export your meshes, thus making the export process faster.
For example, if you have only changed your render settings or material settings since you last rendered, you can use the "Quick Export" option to benefit from a faster update to the already exported scene.
Render Selected Entities
Export and start rendering only the currently selected entities in your SketchUp scene.
Material Editor
Open the SkIndigo material editor.
Render Settings
Open the SkIndigo render settings dialog.
